How to Repair a Loose Armrest in a Camping Chair
  1. How to Repair a Loose Armrest in a Camping Chair, Identify the repair area: step 1, image 1 of 3 How to Repair a Loose Armrest in a Camping Chair, Identify the repair area: step 1, image 2 of 3 How to Repair a Loose Armrest in a Camping Chair, Identify the repair area: step 1, image 3 of 3
    • Locate the joint mechanism that connects the arm to the rest of the chair.
    • In this example, the arm of the chair used to be connected by a screw that has gone missing and now there are two holes left (red circles).
  2. How to Repair a Loose Armrest in a Camping Chair, Find a replacement screw: step 2, image 1 of 3 How to Repair a Loose Armrest in a Camping Chair, Find a replacement screw: step 2, image 2 of 3 How to Repair a Loose Armrest in a Camping Chair, Find a replacement screw: step 2, image 3 of 3
    • Use the other chair arm as an example to find the right screw size (yellow circle).
    • Using a screwdriver, remove the screw from the chair arm.
    • Set this screw aside to check the replacement part.
  3. How to Repair a Loose Armrest in a Camping Chair, Select and test the replacement: step 3, image 1 of 3 How to Repair a Loose Armrest in a Camping Chair, Select and test the replacement: step 3, image 2 of 3 How to Repair a Loose Armrest in a Camping Chair, Select and test the replacement: step 3, image 3 of 3
    • Compare the example screw with the spare parts and choose the piece that resembles it the most.
    • Once you have selected the replacement, test it to see if it fits in the right size.
    • For the testing, introduce the screw and then try pushing it outwards (red arrow).
    • Note: The right replacement should stay in place.
  4. How to Repair a Loose Armrest in a Camping Chair, Screw on the replacement: step 4, image 1 of 3 How to Repair a Loose Armrest in a Camping Chair, Screw on the replacement: step 4, image 2 of 3 How to Repair a Loose Armrest in a Camping Chair, Screw on the replacement: step 4, image 3 of 3
    • Once you have the right replacement, you should screw the piece in the right place.
    • Tip: Make sure the the screw is passing through the cloth part and metal structure of the chair.
    • After securing the new replacement, you can reassemble the other chair arm that was used as an example.
  5. How to Repair a Loose Armrest in a Camping Chair, Finished and ready!: step 5, image 1 of 2 How to Repair a Loose Armrest in a Camping Chair, Finished and ready!: step 5, image 2 of 2
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
5,208 Reputation
48 Guides authored
INTERSPORT Member of INTERSPORT
Community
17 Members
60 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 45
All Time: 55
