Introduction
After many adventures out in the woods, your sleeping bag may suffer a seam split. We will show you a quick solution on how to fix it that can be applied even while you are still out there!
Find a matching color thread and prepare the needle.
Make a double thread and add a little knot at the end.
Make sure that the needle is in a position that is perpendicular to the edge of the seam (red arrow).
Take turns going up and down following line of the seam.
Note For this example we are doing an "invisible" stitch that provides a subtle solution to the split.
Secure the stitch by pulling the thread tighter as you go.
Continue until you reach the end of the split.
Add a knot at the end of the stitch.
Use a pair of scissors to clean the loose threads.
🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
