Introduction
If you've noticed the rubber on your shoe's midsole starting to peel away, don't worry β you can easily repair it at home. We will walk you through the steps to fix rubber delamination, ensuring your shoes stay comfortable and functional.
If you need to fix an upper delamination, check out this guide
Use a rough piece of sandpaper to rub-off the remaining glue residue and to roughen the surface for enhanced glue adhesion.
Be careful not to damage the material below the midsole.
Apply the glue to both the sole and the separated part.
Apply pressure using clamps.
Note: Follow the instructions of the glue used to know the exact drying time. In this example we left the product to dry overnight.
π οΈππ Congratulations! The repair is complete, and you're ready to go!
In need of another repair? Don't worry! Check out our other guidesΒ to find quick solutions for your favourite clothing, footwear and equipment!
