How to Repair the Buttons on a Logitech Pebble Mouse
  1. How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: step 1, image 1 of 3 How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: step 1, image 2 of 3 How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: step 1, image 3 of 3
    • Use your hands to remove the magnetic top panel of the mouse.
  2. How to Repair the Buttons on a Logitech Pebble Mouse: step 2, image 1 of 3 How to Repair the Buttons on a Logitech Pebble Mouse: step 2, image 2 of 3 How to Repair the Buttons on a Logitech Pebble Mouse: step 2, image 3 of 3
    • Remove the USB adaptor in the small rectangular hole on the lower right corner.
    • Remove the battery.
  3. How to Repair the Buttons on a Logitech Pebble Mouse: step 3, image 1 of 2 How to Repair the Buttons on a Logitech Pebble Mouse: step 3, image 2 of 2
    • Use a Phillips #000 screwdriver to remove one screw holding the inner panel in place.
  4. How to Repair the Buttons on a Logitech Pebble Mouse: step 4, image 1 of 3 How to Repair the Buttons on a Logitech Pebble Mouse: step 4, image 2 of 3 How to Repair the Buttons on a Logitech Pebble Mouse: step 4, image 3 of 3
    • Remove the the inner panel.
    • This may take a little bit of effort but it should come off fairly easily.
    • You can use the battery socket as leverage to remove the panel. To avoid breaking the panel, be gentle but firm.
  5. How to Repair the Buttons on a Logitech Pebble Mouse: step 5, image 1 of 1
    • Use a fine-tipped object or a Q-tip and dip it in a small amount of oil.
  6. How to Repair the Buttons on a Logitech Pebble Mouse: step 6, image 1 of 3 How to Repair the Buttons on a Logitech Pebble Mouse: step 6, image 2 of 3 How to Repair the Buttons on a Logitech Pebble Mouse: step 6, image 3 of 3
    • Gently wipe the metal axle where the scroll wheel is mounted with a small amount of 3-in-1 oil.
    • Repeat for the left and right click buttons.
Emma Whitmer
151 Reputation
1 Guide authored
UC Davis, Team 2-6, Morris Spring 2023 Member of UC Davis, Team 2-6, Morris Spring 2023
UCD-MORRIS-S23S2G6
3 Members
1 Guide authored
2 Comments
At first i'm laugh about fixing button with oil, but then i tried it... and it worked like a charm!
Marat - Reply
I didn't even disassemble (unscrew) my pebble. Just applied a drop of mineral oil to the button and it did help a lot! Thanks!
Tomek Luzak - Reply
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 130
All Time: 1,786
