How to Repair the Sparker on a Merlion Mini Torch
  1. How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: step 1, image 1 of 3 How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: step 1, image 2 of 3 How to Repair the Sparker on a Merlion Mini Torch, How to Repair the Sparker on a Merlion Mini Torch: step 1, image 3 of 3
    • Use the screwdriver to remove all the 1.2 mm Phillips #1 countersunk screws from the torch.
  2. How to Repair the Sparker on a Merlion Mini Torch: step 2, image 1 of 2 How to Repair the Sparker on a Merlion Mini Torch: step 2, image 2 of 2
    • Open up the torch.
    • Set aside the empty side of the torch.
  3. How to Repair the Sparker on a Merlion Mini Torch: step 3, image 1 of 3 How to Repair the Sparker on a Merlion Mini Torch: step 3, image 2 of 3 How to Repair the Sparker on a Merlion Mini Torch: step 3, image 3 of 3
    • Pull the handle down as if you were to use the torch.
    • You will see one of the parts inside spark. This is the sparker.
    • Now gently remove the handle and set it aside.
  4. How to Repair the Sparker on a Merlion Mini Torch: step 4, image 1 of 2 How to Repair the Sparker on a Merlion Mini Torch: step 4, image 2 of 2
    • Grab your pliers and GENTLY tug the sparker towards the Merlion head until it is extended about a centimeter.
  5. How to Repair the Sparker on a Merlion Mini Torch: step 5, image 1 of 2 How to Repair the Sparker on a Merlion Mini Torch: step 5, image 2 of 2
    • Gently bend the sparker until it is positioned near the opening of the Merlion's mouth.
  6. How to Repair the Sparker on a Merlion Mini Torch: step 6, image 1 of 3 How to Repair the Sparker on a Merlion Mini Torch: step 6, image 2 of 3 How to Repair the Sparker on a Merlion Mini Torch: step 6, image 3 of 3
    • Grab the tube and gently bend it so it faces the opening of the Merlion's mouth.
    • Put the handle back on the torch.
  7. How to Repair the Sparker on a Merlion Mini Torch: step 7, image 1 of 3 How to Repair the Sparker on a Merlion Mini Torch: step 7, image 2 of 3 How to Repair the Sparker on a Merlion Mini Torch: step 7, image 3 of 3
    • Take the empty half of the torch and place it over the other half.
  8. How to Repair the Sparker on a Merlion Mini Torch: step 8, image 1 of 3 How to Repair the Sparker on a Merlion Mini Torch: step 8, image 2 of 3 How to Repair the Sparker on a Merlion Mini Torch: step 8, image 3 of 3
    • Use the screwdriver to put the screws back in the torch.
  9. How to Repair the Sparker on a Merlion Mini Torch: step 9, image 1 of 2 How to Repair the Sparker on a Merlion Mini Torch: step 9, image 2 of 2
    • Hold the torch upside down and position the butane above the torch's hole.
    • Gently press down for five seconds.
Congrats! Now you can use your Merlion torch again.
3 other people completed this guide.
Neel Kogali
200 Reputation
1 Guide authored
Cal Poly, Team 14-3, Green Fall 2015 Member of Cal Poly, Team 14-3, Green Fall 2015
CPSU-GREEN-F15S14G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 20
All Time: 7,615
