How to Replace Concealed Cabinet Hinges
  1. How to Replace Concealed Cabinet Hinges, Hinge: step 1, image 1 of 3 How to Replace Concealed Cabinet Hinges, Hinge: step 1, image 2 of 3 How to Replace Concealed Cabinet Hinges, Hinge: step 1, image 3 of 3
    • Remove the screws that are attached to the cabinet door.
    • Unscrew the top and bottom hinges even if you are only replacing one hinge.
    • Remove the cabinet door from the hinge.
    • You may need to wiggle or pry the door off.
  2. How to Replace Concealed Cabinet Hinges: step 2, image 1 of 2 How to Replace Concealed Cabinet Hinges: step 2, image 2 of 2
    • Remove the screws that go into the cabinet frame from the hinge, then remove the hinge.
    • Only the hinge being replaced needs to be removed.
  3. How to Replace Concealed Cabinet Hinges: step 3, image 1 of 3 How to Replace Concealed Cabinet Hinges: step 3, image 2 of 3 How to Replace Concealed Cabinet Hinges: step 3, image 3 of 3
    • Insert the new hinge into the cabinet door's pre-cut hole.
    • Attach the hinge with the provided screws.
    • To avoid striping the screws, do not over tighten.
  4. How to Replace Concealed Cabinet Hinges: step 4, image 1 of 1
    • Reattach the cabinet door to the cabinet frame.
    • Do not tighten the screws all the way. You will need to align the door later.
    • You may need a friend to hold the door while you screw it back into place.
  5. How to Replace Concealed Cabinet Hinges: step 5, image 1 of 2 How to Replace Concealed Cabinet Hinges: step 5, image 2 of 2
    • Lift or lower the cabinet door to align the hinges with its original location.
    • Changes in wood stain can serve as a useful alignment guide.
    • Tighten all the screws.
  6. How to Replace Concealed Cabinet Hinges: step 6, image 1 of 3 How to Replace Concealed Cabinet Hinges: step 6, image 2 of 3 How to Replace Concealed Cabinet Hinges: step 6, image 3 of 3
    • Use this step to adjust the amount of space between the cabinet door and the cabinet frame.
    • Loosen the adjustment screws, but do not remove them.
    • Slide the cabinet door to your desired position.
    • Tighten the screws.
  7. How to Replace Concealed Cabinet Hinges: step 7, image 1 of 1
    • Use this step if your cabinet door closes too hard or does not completely close.
    • Tighten this screw to keep the cabinet door from closing too hard. Loosen the screw to allow the cabinet door to close completely.
    • Do not completely remove this screw.
Finish Line
4 other people completed this guide.
Naomi Frazier
171 Reputation
1 Guide authored
UC Davis, Team S4-G4, Cole Spring 2017 Member of UC Davis, Team S4-G4, Cole Spring 2017
UCD-COLE-S17S4G4
3 Members
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 103
All Time: 28,079
