How to Replace Field Hockey Stick Grip Tape
  1. How to Replace Field Hockey Stick Grip Tape, Grip Tape: step 1, image 1 of 3 How to Replace Field Hockey Stick Grip Tape, Grip Tape: step 1, image 2 of 3 How to Replace Field Hockey Stick Grip Tape, Grip Tape: step 1, image 3 of 3
    • Use a cloth and an anti-bacterial spray to clean the Field Hockey stick.
  2. How to Replace Field Hockey Stick Grip Tape: step 2, image 1 of 3 How to Replace Field Hockey Stick Grip Tape: step 2, image 2 of 3 How to Replace Field Hockey Stick Grip Tape: step 2, image 3 of 3
    • Unravel the old sticky tape starting from the top of the stick.
  3. How to Replace Field Hockey Stick Grip Tape: step 3, image 1 of 3 How to Replace Field Hockey Stick Grip Tape: step 3, image 2 of 3 How to Replace Field Hockey Stick Grip Tape: step 3, image 3 of 3
    • Unravel old tape until it meets the end of the handle.
  4. How to Replace Field Hockey Stick Grip Tape: step 4, image 1 of 2 How to Replace Field Hockey Stick Grip Tape: step 4, image 2 of 2
    • Carefully cut the tape so that end of grip tape below can be taken off.
    • Handle scissors with care never holding the open blade.
  5. How to Replace Field Hockey Stick Grip Tape: step 5, image 1 of 3 How to Replace Field Hockey Stick Grip Tape: step 5, image 2 of 3 How to Replace Field Hockey Stick Grip Tape: step 5, image 3 of 3
    • Unravel the old grip tape from the top of the stick that spirals down.
    • Stop unravelling once loose-end cap is exposed fully.
  6. How to Replace Field Hockey Stick Grip Tape: step 6, image 1 of 2 How to Replace Field Hockey Stick Grip Tape: step 6, image 2 of 2
    • Put glue around the circumference of the base of the loose cap.
    • Line up and press the cap back onto the stick.
    • Handle glue with care so as not to spill.
  7. How to Replace Field Hockey Stick Grip Tape: step 7, image 1 of 1
    • Let the glue dry for at least 10 minutes.
  8. How to Replace Field Hockey Stick Grip Tape: step 8, image 1 of 3 How to Replace Field Hockey Stick Grip Tape: step 8, image 2 of 3 How to Replace Field Hockey Stick Grip Tape: step 8, image 3 of 3
    • Using new gauze tape, re-wrap the stick applying pressure in an upwards motion.
  9. How to Replace Field Hockey Stick Grip Tape: step 9, image 1 of 2 How to Replace Field Hockey Stick Grip Tape: step 9, image 2 of 2
    • Once new gauze covers the handle, cut the tape from its source.
  10. How to Replace Field Hockey Stick Grip Tape: step 10, image 1 of 3 How to Replace Field Hockey Stick Grip Tape: step 10, image 2 of 3 How to Replace Field Hockey Stick Grip Tape: step 10, image 3 of 3
    • Secure the gauze with sticky tape at the top of the handle.
    • Cut the sticky tape from its source before wrapping around the top of the handle.
  11. How to Replace Field Hockey Stick Grip Tape: step 11, image 1 of 3 How to Replace Field Hockey Stick Grip Tape: step 11, image 2 of 3 How to Replace Field Hockey Stick Grip Tape: step 11, image 3 of 3
    • Secure the gauze with sticky tape at the bottom of the handle.
    • Cut the sticky tape from its source before wrapping around the bottom of the handle.
  12. How to Replace Field Hockey Stick Grip Tape: step 12, image 1 of 1
    • Enjoy your new grip tape!
Finish Line
Sophia Juan
205 Reputation
1 Guide authored
UC Davis, Team 1-5, Andersen Winter 2024 Member of UC Davis, Team 1-5, Andersen Winter 2024
UCD-ANDERSEN-W24S1G5
3 Members
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 111
