How to Replace Hot and Cold Water Pipes for a Washer
  1. How to Replace Hot and Cold Water Pipes for a Washer, How to Replace Hot and Cold Water Pipes for a Washer: step 1, image 1 of 1
    • Before starting this guide, shut off your water to the washer and dryer. In this guide, valves are used. Some newer setups may use levers.
    • Mark the hot and cold water pipelines with a marker for proper visuals.
    • Hot water
    • Cold water
  2. How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: step 2, image 1 of 3 How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: step 2, image 2 of 3 How to Replace Hot and Cold Water Pipes for a Washer, Disconnect the pipes: step 2, image 3 of 3
    • Using an adjustable wrench, disconnect the pipes carefully from the water supply side and the washer side.
    • After the pipes are disconnected, re-check the leakage and rust in the washer installation.
  3. How to Replace Hot and Cold Water Pipes for a Washer: step 3, image 1 of 1
    • Rotate the adjustable wrench in a counter-clockwise direction to loosen the pipe connection.
    • Make sure to remove the old white Teflon tape. Use a bucket and a piece of cloth for water damps from the connection.
  4. How to Replace Hot and Cold Water Pipes for a Washer, Prepare the new pipes: step 4, image 1 of 1
    • Set up the new pipes to be installed.
    • Check for blockage or any cracks in the valve.
  5. How to Replace Hot and Cold Water Pipes for a Washer, Wrap new Teflon tape: step 5, image 1 of 1
    • Wrap the new piece of Teflon tape around the shut-off valve connection.
  6. How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: step 6, image 1 of 3 How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: step 6, image 2 of 3 How to Replace Hot and Cold Water Pipes for a Washer, Install the new pipes: step 6, image 3 of 3
    • Install and connect the new pipes using an adjustable wrench.
  7. How to Replace Hot and Cold Water Pipes for a Washer, Return the water supply: step 7, image 1 of 2 How to Replace Hot and Cold Water Pipes for a Washer, Return the water supply: step 7, image 2 of 2
    • Rotate the pipes in a clockwise direction to tighten up.
    • Turn on the water supply. Perform a quick wash and check the connection.
  • This guide contains easy steps of instructions to be followed if your pipes of the washer are needed to be changed.
Jenish
169 Reputation
1 Guide authored
One Comment
Those are hoses. Pipes are in the wall
NitWit - Reply
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 185
All Time: 7,922
