How to Replace Waistband Elastic to Sleep Pants
  1. How to Replace Waistband Elastic to Sleep Pants, Waistband Elastic: step 1, image 1 of 1
    • Measure your waist by wrapping the cloth measuring tape around your body about two inches above your hip bones. Make sure the tape lays flat against your body.
    • Where the tape overlaps is your waist measurement.
  2. How to Replace Waistband Elastic to Sleep Pants: step 2, image 1 of 2 How to Replace Waistband Elastic to Sleep Pants: step 2, image 2 of 2
    • Measure the elastic to waist measurement plus one more inch to ensure room to sew. Mark the elastic for cutting.
    • Cut the elastic. Cut on the side away from your measured length.
    • Extra length is better than too little elastic.
  3. How to Replace Waistband Elastic to Sleep Pants: step 3, image 1 of 2 How to Replace Waistband Elastic to Sleep Pants: step 3, image 2 of 2
    • At the back of the waistband, use the seam ripper to break the threads of the waistband to create an opening.
    • Through the opening, pull out any ribbon or old elastic your are replacing.
  4. How to Replace Waistband Elastic to Sleep Pants: step 4, image 1 of 2 How to Replace Waistband Elastic to Sleep Pants: step 4, image 2 of 2
    • Tape the elastic to the end of a pencil or another straight object to guide the elastic.
    • Carefully insert the pencil and elastic into the casing through the opening you made.
    • Pin the back edge of the elastic to the sleep pants. This stops the entire elastic piece from going through the waistband.
    • Push the entire length of the pencil into the casing until the elastic starts going through the casing.
    • Continue to pull gently, until the pencil and elastic are out of the other side of the opening where you started.
    • Remove the pencil and tape from the elastic.
  5. How to Replace Waistband Elastic to Sleep Pants: step 5, image 1 of 2 How to Replace Waistband Elastic to Sleep Pants: step 5, image 2 of 2
    • Overlap both ends of the elastic the extra inch you included for sewing. Secure with two pins.
    • Using thread and a needle to sew the elastic together.
    • For strength, overlap two stitches to form an X pattern. Repeat the length of the elastic.
  6. How to Replace Waistband Elastic to Sleep Pants: step 6, image 1 of 2 How to Replace Waistband Elastic to Sleep Pants: step 6, image 2 of 2
    • Before sewing the seams closed, distribute any bunched fabric.
    • Remove bunched fabric by: pulling your hands apart gently and stretch the elastic to the full size of the cloth waistband.
  7. How to Replace Waistband Elastic to Sleep Pants: step 7, image 1 of 3 How to Replace Waistband Elastic to Sleep Pants: step 7, image 2 of 3 How to Replace Waistband Elastic to Sleep Pants: step 7, image 3 of 3
    • Stabilize elastic from moving by stitching at the vertical seams. Add one or two stitches at the seams to hold the elastic from moving within the casing.
    • Sew the opening you made closed.
Enjoy your newly fitted sleep pants.
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 36
All Time: 2,494
