How to Replace a Broken Window Wand Tilt Mechanism
  1. How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: step 1, image 1 of 3 How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: step 1, image 2 of 3 How to Replace a Broken Window Wand Tilt Mechanism, Wand Tilt Mechanism: step 1, image 3 of 3
    • Lift up the wand sleeve with your fingers to clear access for the wand to slide out.
    • Once the sleeve is pushed up, rotate the wand horizontally to unhook it from the tilt mechanism.
  2. How to Replace a Broken Window Wand Tilt Mechanism: step 2, image 1 of 2 How to Replace a Broken Window Wand Tilt Mechanism: step 2, image 2 of 2
    • Lift the header board off the window shade by gently prying up and away from the window blind.
  3. How to Replace a Broken Window Wand Tilt Mechanism: step 3, image 1 of 3 How to Replace a Broken Window Wand Tilt Mechanism: step 3, image 2 of 3 How to Replace a Broken Window Wand Tilt Mechanism: step 3, image 3 of 3
    • Unhook the end clips on the window blind by pulling with your fingers toward yourself in an upward motion.
  4. How to Replace a Broken Window Wand Tilt Mechanism: step 4, image 1 of 2 How to Replace a Broken Window Wand Tilt Mechanism: step 4, image 2 of 2
    • Remove the window blind by pulling it away from the brackets.
  5. How to Replace a Broken Window Wand Tilt Mechanism: step 5, image 1 of 3 How to Replace a Broken Window Wand Tilt Mechanism: step 5, image 2 of 3 How to Replace a Broken Window Wand Tilt Mechanism: step 5, image 3 of 3
    • Slide the end cap off the header to allow for more access.
    • Lift the center rod in an upward motion to unlock it from the header.
  6. How to Replace a Broken Window Wand Tilt Mechanism: step 6, image 1 of 3 How to Replace a Broken Window Wand Tilt Mechanism: step 6, image 2 of 3 How to Replace a Broken Window Wand Tilt Mechanism: step 6, image 3 of 3
    • Remove the tilt wand mechanism by sliding it off the center rod.
  7. How to Replace a Broken Window Wand Tilt Mechanism: step 7, image 1 of 3 How to Replace a Broken Window Wand Tilt Mechanism: step 7, image 2 of 3 How to Replace a Broken Window Wand Tilt Mechanism: step 7, image 3 of 3
    • Install the new tilt wand mechanism by sliding it on the center rod.
    • Once slid into position, reinsert the center rod by pushing down on the assembly.
  8. How to Replace a Broken Window Wand Tilt Mechanism: step 8, image 1 of 1
    • Visually inspect alignment, fitment, and proper function of the newly installed tilt wand mechanism.
    • Insure the clip is securely held in place.
2 other people completed this guide.
0 Comments
Past 24 Hours: 20
Past 7 Days: 124
Past 30 Days: 532
All Time: 18,050
