How to Replace a Leaking Set Screw Tub Spout
  1. How to Replace a Leaking Set Screw Tub Spout, Set Screw Tub Spout: step 1, image 1 of 2 How to Replace a Leaking Set Screw Tub Spout, Set Screw Tub Spout: step 1, image 2 of 2
    • Cover the shower drain with a plug or a piece of cloth to prevent the screw from falling in.
    • Make sure the water is turned off.
  2. How to Replace a Leaking Set Screw Tub Spout: step 2, image 1 of 3 How to Replace a Leaking Set Screw Tub Spout: step 2, image 2 of 3 How to Replace a Leaking Set Screw Tub Spout: step 2, image 3 of 3
    • Using an 5/32" Allen key, loosen the screw located under the spout.
    • You should not remove the screw. But instead, untighten the screw until it's loose.
  3. How to Replace a Leaking Set Screw Tub Spout: step 3, image 1 of 3 How to Replace a Leaking Set Screw Tub Spout: step 3, image 2 of 3 How to Replace a Leaking Set Screw Tub Spout: step 3, image 3 of 3
    • Gently pull out the spout using your hand and set it aside somewhere.
    • Protip: Wiggle the spout side to side to help pull it out.
  4. How to Replace a Leaking Set Screw Tub Spout: step 4, image 1 of 3 How to Replace a Leaking Set Screw Tub Spout: step 4, image 2 of 3 How to Replace a Leaking Set Screw Tub Spout: step 4, image 3 of 3
    • Using sandpaper or a sponge, gently rub and clean the pipe.
    • This allows for the new set screw tub spout to easily slip on.
    • Once you have finished cleaning the pipe, wipe off the dust with a piece of cloth or paper towel.
  5. How to Replace a Leaking Set Screw Tub Spout: step 5, image 1 of 3 How to Replace a Leaking Set Screw Tub Spout: step 5, image 2 of 3 How to Replace a Leaking Set Screw Tub Spout: step 5, image 3 of 3
    • Take your new set screw tub spout and slide it in gently into the wall.
    • Protip: Wiggle the spout side to side to help push it back in.
  6. How to Replace a Leaking Set Screw Tub Spout: step 6, image 1 of 3 How to Replace a Leaking Set Screw Tub Spout: step 6, image 2 of 3 How to Replace a Leaking Set Screw Tub Spout: step 6, image 3 of 3
    • Retighten the set screw using the 5/32" Allen key.
Turn on the bath water to ensure the set screw tub spout has no leaks and is working as intended.
2 other people completed this guide.
Hadjie Figueroa
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 61
All Time: 4,008
