How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock
  1. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock, Door Lock: step 1, image 1 of 3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock, Door Lock: step 1, image 2 of 3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock, Door Lock: step 1, image 3 of 3
    • Unscrew the lockbolt of the old door and remove it.
  2. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 2, image 1 of 2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 2, image 2 of 2
    • Match the adapter to a position where it fits into the middle hole of the door’s lock spot.
  3. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 3, image 1 of 2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 3, image 2 of 2
    • Attach the two door mounting plates together, aligning the holes between the two plates.
  4. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 4, image 1 of 2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 4, image 2 of 2
    • Once attached together, flip it the other way and attach it to the lock spot.
  5. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 5, image 1 of 3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 5, image 2 of 3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 5, image 3 of 3
    • Screw the screws back in.
  6. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 6, image 1 of 3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 6, image 2 of 3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 6, image 3 of 3
    • Flip your August Smart Lock (4 Gen.) so that the back faces the door.
    • Make sure that both of its side wing latches are still open.
  7. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 7, image 1 of 3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 7, image 2 of 3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 7, image 3 of 3
    • Attach the lock to the mounting plates, matching it in the center of the adapter’s tailpiece shape to see how it fits.
    • This may take some rotating to see how it can fit on best.
  8. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 8, image 1 of 2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 8, image 2 of 2
    • Once fit, proceed to close both of the open wing latches on the smart lock.
  9. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 9, image 1 of 3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 9, image 2 of 3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 9, image 3 of 3
    • Gently push on the ‘August’ logo on the front cover of the electronic lock to lift the front cover (the magnetic buckle).
    • Here, you will find the batteries’ placement area.
  10. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 10, image 1 of 3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 10, image 2 of 3 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 10, image 3 of 3
    • If sealed, remove/tear off the plastic seal, then put the given lithium batteries in their designated area.
    • Make sure to place them the right side up - keep in mind that the negative attracts the positive.
  11. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 11, image 1 of 2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 11, image 2 of 2
    • After doing so, you’ll see the ‘August’ Smart Lock flash a green light.
    • Once that happens, put the front cover back on.
  12. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 12, image 1 of 2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 12, image 2 of 2
    • Download and configure the August Smart Lock application on your cellular device.
    • Follow the on-screen instructions to connect to your lock.
    • Pay attention to the light coming from the logo as you proceed.
  13. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 13, image 1 of 2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 13, image 2 of 2
    • Once done, test the application by pressing your phone screen to lock your door.
  14. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 14, image 1 of 2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 14, image 2 of 2
    • Test the application again by pressing your phone screen to unlock your door this time.
  15. How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 15, image 1 of 2 How to Replace a Manual Door Lock With An August (4th Gen.) Smart Lock: step 15, image 2 of 2
    • Your new Wi-Fi controlled smart lock should now be ready to use at any time.
Don’t forget to change the lock’s batteries regularly to avoid locking you or anyone else out by accident.
You can learn more information on installing the August Smart Lock at https://www.acslocks.com/how-to-install-....
Ratula Chakrabarti
241 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 20
All Time: 227
