How to Replace a Nequare Cordless Vacuum S182 Filter
  1. How to Replace a Nequare Cordless Vacuum S182 Filter, Filter: step 1, image 1 of 2 How to Replace a Nequare Cordless Vacuum S182 Filter, Filter: step 1, image 2 of 2
    • Locate the black button to release the white motor unit from the rest of the vacuum cleaner.
  2. How to Replace a Nequare Cordless Vacuum S182 Filter: step 2, image 1 of 2 How to Replace a Nequare Cordless Vacuum S182 Filter: step 2, image 2 of 2
    • Hold down the black button to remove the white motor unit above and gently pull the motor unit upwards.
  3. How to Replace a Nequare Cordless Vacuum S182 Filter: step 3, image 1 of 2 How to Replace a Nequare Cordless Vacuum S182 Filter: step 3, image 2 of 2
    • Press the release button at the side of the dust canister to dispose of the debris.
    • Be sure to hold the the canister over a garbage can to avoid a spill.
  4. How to Replace a Nequare Cordless Vacuum S182 Filter: step 4, image 1 of 3 How to Replace a Nequare Cordless Vacuum S182 Filter: step 4, image 2 of 3 How to Replace a Nequare Cordless Vacuum S182 Filter: step 4, image 3 of 3
    • After emptying the debris, hold down the black button, then twist and pull the canister out.
  5. How to Replace a Nequare Cordless Vacuum S182 Filter: step 5, image 1 of 2 How to Replace a Nequare Cordless Vacuum S182 Filter: step 5, image 2 of 2
    • Take the filter out and dispose of it.
  6. How to Replace a Nequare Cordless Vacuum S182 Filter: step 6, image 1 of 2 How to Replace a Nequare Cordless Vacuum S182 Filter: step 6, image 2 of 2
    • Remove the black part by gently pushing from inside of the canister.
  7. How to Replace a Nequare Cordless Vacuum S182 Filter: step 7, image 1 of 2 How to Replace a Nequare Cordless Vacuum S182 Filter: step 7, image 2 of 2
    • Clean both the canister and the black part either by rinsing it out or using a wash cloth.
  8. How to Replace a Nequare Cordless Vacuum S182 Filter: step 8, image 1 of 3 How to Replace a Nequare Cordless Vacuum S182 Filter: step 8, image 2 of 3 How to Replace a Nequare Cordless Vacuum S182 Filter: step 8, image 3 of 3
    • Put the black part back into the canister and put in the new filter.
Oghenefejiro Egede
181 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 36
All Time: 1,338
