How to Replace a Pony 42 Troy-Bilt Riding Lawnmower Fuel Filter
  1. How to Replace a Pony 42 Troy-Bilt Riding Lawnmower Fuel Filter, Fuel Filter: step 1, image 1 of 1
    • Orient yourself facing the front of the lawnmower. After opening the hood, the fuel filter will be located on the right side of the engine.
    • Identify the fuel line from your gas tank and trace it to your fuel filter.
  2. How to Replace a Pony 42 Troy-Bilt Riding Lawnmower Fuel Filter: step 2, image 1 of 2 How to Replace a Pony 42 Troy-Bilt Riding Lawnmower Fuel Filter: step 2, image 2 of 2
    • Slide the metal clip located on the right side closest to the filter, using your pliers, and slide the clip down the fuel line.
  3. How to Replace a Pony 42 Troy-Bilt Riding Lawnmower Fuel Filter: step 3, image 1 of 2 How to Replace a Pony 42 Troy-Bilt Riding Lawnmower Fuel Filter: step 3, image 2 of 2
    • Using your pliers, slide the metal clip located on the left side closest to the filter down the fuel line.
  4. How to Replace a Pony 42 Troy-Bilt Riding Lawnmower Fuel Filter: step 4, image 1 of 3 How to Replace a Pony 42 Troy-Bilt Riding Lawnmower Fuel Filter: step 4, image 2 of 3 How to Replace a Pony 42 Troy-Bilt Riding Lawnmower Fuel Filter: step 4, image 3 of 3
    • Use a shop towel or rag to wipe the fuel line to check for leaks.
    • Firmly grasp the fuel line with your right hand, and hold the fuel filter steady with your left hand.
    • With a pulling and twisting motion, remove the fuel line from the fuel filter.
    • Use your shop towel or rag to absorb any fuel left in the fuel line from spilling.
    • If you have fuel in your fuel tank, then simply hold the fuel line upward to prevent unintentionally draining the fuel tank.
  5. How to Replace a Pony 42 Troy-Bilt Riding Lawnmower Fuel Filter: step 5, image 1 of 1
    • With an approved fuel container, place the end of the fuel line into your container to drain bad fuel.
  6. How to Replace a Pony 42 Troy-Bilt Riding Lawnmower Fuel Filter: step 6, image 1 of 1
    • With a pulling and twisting motion, remove the fuel filter from the fuel line leading into your fuel pump.
    • Some fuel may still be in the line leading to the fuel pump. Use your shop towel or rag to soak residual fuel.
  7. How to Replace a Pony 42 Troy-Bilt Riding Lawnmower Fuel Filter: step 7, image 1 of 1
    • Keep the filter a safe distance from your face and look through one end.
    • You should be able to see light shining through clearly from the other side. If debris is clogging the mesh screen, pleated paper or the inside of the casing, replace the old filter with a new replacement fuel filter.
Eric Soto
172 Reputation
1 Guide authored
2 Comments
The larger diameter side of the filter is supposed to go to the engine side - you have it backwards.
Jenn Hubbert - Reply
In-line fuel filters, in most cases, do have flow directions and it is always best to follow installation instructions for specific parts. The fuel filter in this tutorial is a Briggs and Stratton 75 micron filter that uses a mesh and may be installed in either direction.
Eric Soto -
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 176
All Time: 6,790
