How to Replace a RG-6 Coaxial Cable Connector
  1. How to Replace a RG-6 Coaxial Cable Connector, RG-6 Coaxial Cable Connector: step 1, image 1 of 2 How to Replace a RG-6 Coaxial Cable Connector, RG-6 Coaxial Cable Connector: step 1, image 2 of 2
    • Use a cable cutter to cut your desired length of cable.
    • Cut both ends of the cable at 90 degrees, meaning the cutter and the cable should be positioned at 90 degree of one another.
  2. How to Replace a RG-6 Coaxial Cable Connector: step 2, image 1 of 3 How to Replace a RG-6 Coaxial Cable Connector: step 2, image 2 of 3 How to Replace a RG-6 Coaxial Cable Connector: step 2, image 3 of 3
    • Use a RG-6 coaxial cable stripper to strip each end of the cable.
    • Position the end of cable inside the stripper and rotate it around the cable in a clockwise motion three times. Then, do one full turn counterclockwise.
    • Repeat this on the other end of the cable.
    • After stripping the ends, remove the two pieces of shield cable from the cable.
  3. How to Replace a RG-6 Coaxial Cable Connector: step 3, image 1 of 3 How to Replace a RG-6 Coaxial Cable Connector: step 3, image 2 of 3 How to Replace a RG-6 Coaxial Cable Connector: step 3, image 3 of 3
    • Using your fingers, fan the internal wires out.
    • Mold the braided wires into a flower shape.
    • Remove any excess braid from the core side of the cable (the gold color part).
  4. How to Replace a RG-6 Coaxial Cable Connector: step 4, image 1 of 3 How to Replace a RG-6 Coaxial Cable Connector: step 4, image 2 of 3 How to Replace a RG-6 Coaxial Cable Connector: step 4, image 3 of 3
    • Insert the cable into the thin part of the RG-6 connector.
    • Gently push the cable into the connector. Do not bend or fold the gold portion of the cable.
    • Make sure that the cable's insulator (white portion) and the inside of the connector are flush.
  5. How to Replace a RG-6 Coaxial Cable Connector: step 5, image 1 of 3 How to Replace a RG-6 Coaxial Cable Connector: step 5, image 2 of 3 How to Replace a RG-6 Coaxial Cable Connector: step 5, image 3 of 3
    • To crimp the end of the cable, place one end of the cable into the cable slot of the crimper.
    • Insert one cable end into the appropriate slot for the connector in the crimper.
    • With your thumb, hold down the cable so it will not come out of the cable slot.
  6. How to Replace a RG-6 Coaxial Cable Connector: step 6, image 1 of 1
    • To crimp the connector to the cable, gently pull down the crimper's lever.
    • There is no need to do it multiple times.
    • Secure the connector to both ends of the cable.
  7. How to Replace a RG-6 Coaxial Cable Connector: step 7, image 1 of 3 How to Replace a RG-6 Coaxial Cable Connector: step 7, image 2 of 3 How to Replace a RG-6 Coaxial Cable Connector: step 7, image 3 of 3
    • Check that there is no braid hanging outside of the connector.
    • Loose braids can cause problems with signals.
    • Check that the cables insulation is flush with the connector.
    • If there is loose braid, you'll have to start over from Step 1.
Vic
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 45
Past 30 Days: 228
All Time: 3,844
