How to Replace a Tail Light for a 2011-2015 Ford Explorer
  1. How to Replace a Tail Light for a 2011-2015 Ford Explorer, Tail Light Bulbs: step 1, image 1 of 2 How to Replace a Tail Light for a 2011-2015 Ford Explorer, Tail Light Bulbs: step 1, image 2 of 2
    • Lift and open the rear cargo door.
  2. How to Replace a Tail Light for a 2011-2015 Ford Explorer: step 2, image 1 of 1
    • Locate the two plastic screw covers that are adjacent to the rear light covers.
  3. How to Replace a Tail Light for a 2011-2015 Ford Explorer: step 3, image 1 of 1
    • Using a flathead screwdriver, pry out both plastic screw covers.
  4. How to Replace a Tail Light for a 2011-2015 Ford Explorer: step 4, image 1 of 1
    • Once covers are removed, there will be an 8 mm hex head screw located beneath each cover.
  5. How to Replace a Tail Light for a 2011-2015 Ford Explorer: step 5, image 1 of 1
    • Using an 8 mm Deep Socket Wrench, remove both of the 20 mm (length) hex-head screws.
  6. How to Replace a Tail Light for a 2011-2015 Ford Explorer: step 6, image 1 of 2 How to Replace a Tail Light for a 2011-2015 Ford Explorer: step 6, image 2 of 2
    • Gently pull the tail light cover from the car.
    • You may have to gently play with the cover by moving it back and forth in order to pry it loose form the car.
  7. How to Replace a Tail Light for a 2011-2015 Ford Explorer: step 7, image 1 of 1
    • Once removed, the bulb sockets will be located on the inside portion of the tail light cover.
  8. How to Replace a Tail Light for a 2011-2015 Ford Explorer: step 8, image 1 of 1
    • Turn the bulb socket about one quarter turn in a counterclockwise direction.
    • After it is turned, gently pull and remove the bulb socket from the tail light cover.
  9. How to Replace a Tail Light for a 2011-2015 Ford Explorer: step 9, image 1 of 1
    • Gently remove the bulb from the bulb socket.
  10. How to Replace a Tail Light for a 2011-2015 Ford Explorer: step 10, image 1 of 1
    • Gently place the new bulb in the bulb socket.
8 other people completed this guide.
Michael Lynch
317 Reputation
1 Guide authored
Cal Poly, Team 14-4, Green Fall 2015 Member of Cal Poly, Team 14-4, Green Fall 2015
CPSU-GREEN-F15S14G4
5 Members
16 Guides authored
One Comment
That's not the tail lights that is the turn signal and back up lights.
Djay Glass - Reply
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 109
All Time: 22,046
