How to Replace the Arm of Standard Hinge Eyeglasses
  1. How to Replace the Arm of Standard Hinge Eyeglasses, Eyeglasses Arm: step 1, image 1 of 2 How to Replace the Arm of Standard Hinge Eyeglasses, Eyeglasses Arm: step 1, image 2 of 2
    • Remove the screw holding the broken arm by turning it counterclockwise.
  2. How to Replace the Arm of Standard Hinge Eyeglasses: step 2, image 1 of 1
    • Carefully set the screw aside and discard the broken arm.
  3. How to Replace the Arm of Standard Hinge Eyeglasses: step 3, image 1 of 1
    • Thoroughly clean the screw and the connecting hinge using the cleaning cloth to remove any dirt or buildup.
  4. How to Replace the Arm of Standard Hinge Eyeglasses: step 4, image 1 of 2 How to Replace the Arm of Standard Hinge Eyeglasses: step 4, image 2 of 2
    • Align the joints of the new arm with the joint connected to the frame.
    • The frame joint should be in between the two joints of the arm.
  5. How to Replace the Arm of Standard Hinge Eyeglasses: step 5, image 1 of 3 How to Replace the Arm of Standard Hinge Eyeglasses: step 5, image 2 of 3 How to Replace the Arm of Standard Hinge Eyeglasses: step 5, image 3 of 3
    • Insert the screw in the hinge and lightly tighten by turning the screw clockwise.
    • Make sure all parts are aligned and that the new arm is not angled.
    • You may want to put the glasses on to make sure the arm is positioned properly.
  6. How to Replace the Arm of Standard Hinge Eyeglasses: step 6, image 1 of 1
    • Once aligned, fully tighten the screw.
    • You may need to make adjustments to the tightness of the arm. Tighten (turn clockwise) or loosen (turn counterclockwise) the screw until you have a comfortable fit.
Finish Line
Mariam
163 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 16
Past 7 Days: 78
Past 30 Days: 299
All Time: 2,490
