How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock
  1. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: step 1, image 1 of 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: step 1, image 2 of 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: step 1, image 3 of 3
    • Remove the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
    • Left side
    • Right side
    • Bottom
  2. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 2, image 1 of 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 2, image 2 of 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 2, image 3 of 3
    • Remove the faceplate from the lock mechanism by pulling straight out.
  3. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 3, image 1 of 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 3, image 2 of 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 3, image 3 of 3
    • Remove the battery pack from the lock mechanism by pulling straight up.
  4. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 4, image 1 of 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 4, image 2 of 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 4, image 3 of 3
    • Remove the batteries from the battery pack.
  5. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 5, image 1 of 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 5, image 2 of 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 5, image 3 of 3
    • Insert new batteries into the battery pack.
  6. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 6, image 1 of 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 6, image 2 of 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 6, image 3 of 3
    • Insert the battery pack back into the lock mechanism by pushing straight down.
    • Make sure the label is facing outward.
  7. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 7, image 1 of 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 7, image 2 of 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 7, image 3 of 3
    • Reattach the faceplate to the lock mechanism by pushing straight in.
  8. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 8, image 1 of 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 8, image 2 of 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: step 8, image 3 of 3
    • Reattach the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
    • Bottom
    • Right side
    • Left side
That's it! Your Kwikset Home Connect 620 Smart Lock should now be working properly.
0 Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 55
All Time: 263
