How to Replace the Fishing Line of a Spinning Reel
  1. How to Replace the Fishing Line of a Spinning Reel, Fishing Line: step 1, image 1 of 1
    • Find the recommended line weights on the side of the reel and purchase the specified line.
    • The side of this reel reads lbs/yrds 6/390, 8/320, or 10,200 so use 6, 8, or 10 pound fishing line.
  2. How to Replace the Fishing Line of a Spinning Reel: step 2, image 1 of 3 How to Replace the Fishing Line of a Spinning Reel: step 2, image 2 of 3 How to Replace the Fishing Line of a Spinning Reel: step 2, image 3 of 3
    • Flip up the metal bail on the spinning reel.
    • Remove the old line by pulling it off the top of the reel.
  3. How to Replace the Fishing Line of a Spinning Reel: step 3, image 1 of 3 How to Replace the Fishing Line of a Spinning Reel: step 3, image 2 of 3 How to Replace the Fishing Line of a Spinning Reel: step 3, image 3 of 3
    • Feed the end of the new line through the first eyelet of the fishing rod.
    • Tie a single overhand knot towards the end of the line.
  4. How to Replace the Fishing Line of a Spinning Reel: step 4, image 1 of 3 How to Replace the Fishing Line of a Spinning Reel: step 4, image 2 of 3 How to Replace the Fishing Line of a Spinning Reel: step 4, image 3 of 3
    • With the bail still up, wrap the line around the reel and tie a double overhand knot.
    • Tighten the line up to the first knot made in the previous step.
  5. How to Replace the Fishing Line of a Spinning Reel: step 5, image 1 of 1
    • Use utility scissors to clip the excess line near the base of the reel.
  6. How to Replace the Fishing Line of a Spinning Reel: step 6, image 1 of 1
    • Place the new spool so it is facing up to prevent line twist.
  7. How to Replace the Fishing Line of a Spinning Reel: step 7, image 1 of 3 How to Replace the Fishing Line of a Spinning Reel: step 7, image 2 of 3 How to Replace the Fishing Line of a Spinning Reel: step 7, image 3 of 3
    • Flip the bail down and slowly reel the line, keeping light tension using your finger.
    • Continue reeling until there is roughly an 1/8th of an inch of radial space left on the reel.
    • Do not overfill the reel with line. This may cause tangles.
  8. How to Replace the Fishing Line of a Spinning Reel: step 8, image 1 of 3 How to Replace the Fishing Line of a Spinning Reel: step 8, image 2 of 3 How to Replace the Fishing Line of a Spinning Reel: step 8, image 3 of 3
    • Use utility scissors to cut the line free of the spool.
    • Clip the free end into the line holder on the side of the reel.
Stefan Venne
157 Reputation
1 Guide authored
UC Davis, Team 2-13, Morris Winter 2023 Member of UC Davis, Team 2-13, Morris Winter 2023
UCD-MORRIS-W23S2G13
1 Member
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 45
All Time: 428
