How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter
  1. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter, Air Filter: step 1, image 1 of 2 How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter, Air Filter: step 1, image 2 of 2
    • Make sure that the motor is off and has had time to cool after being used.
    • Push in the clips on the top of the cover, and remove the cover.
  2. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: step 2, image 1 of 1
    • Make a note of the position of the filter, and remove the cover.
  3. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: step 3, image 1 of 1
    • Lightly bend the filter so that you can see all surfaces of the filter.
  4. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: step 4, image 1 of 1
    • Use compressed air to blow out dirt or dust particles from the air filter.
    • You can bend it in several places to make sure you clean between each of the fins.
  5. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: step 5, image 1 of 1
    • Seat the filter in the same position you made a note of in Step 2.
    • If the filter is still bent from cleaning it, lightly bend it in the opposite direction so that it can lay flat in your hand.
    • Place the cover onto the air filter. This shouldn't require any force, so the filter may need to be readjusted if it does require force.
  6. How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: step 6, image 1 of 2 How to Replace/Maintain a Honda HRR216 Lawn Mower Air Filter: step 6, image 2 of 2
    • Push the clips of the cover in until they click.
    • Check to make sure that the cover is secure, and there are no gaps for dirt or dust to get in.
Finish Line
Pearce McKee
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 45
All Time: 1,445
