How to Reset Your Schlage Connect to Factory Settings
  1. How to Reset Your Schlage Connect to Factory Settings, How to Reset Your Schlage Connect to Factory Settings: step 1, image 1 of 1
    • Ensure the latch is retracted (not locked).
  2. How to Reset Your Schlage Connect to Factory Settings: step 2, image 1 of 1
    • Remove the battery cover by sliding the cover upwards.
  3. How to Reset Your Schlage Connect to Factory Settings: step 3, image 1 of 2 How to Reset Your Schlage Connect to Factory Settings: step 3, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the bottom screw and top screw.
  4. How to Reset Your Schlage Connect to Factory Settings: step 4, image 1 of 1
    • Carefully remove the device from the door.
  5. How to Reset Your Schlage Connect to Factory Settings: step 5, image 1 of 1
    • Locate the programming code behind the alarm device.
    • You will need the original factory's preset user code (listed on the back of the device) for Step 12.
  6. How to Reset Your Schlage Connect to Factory Settings: step 6, image 1 of 3 How to Reset Your Schlage Connect to Factory Settings: step 6, image 2 of 3 How to Reset Your Schlage Connect to Factory Settings: step 6, image 3 of 3
    • Reattach the alarm device to the door by screwing the bottom and top screws.
  7. How to Reset Your Schlage Connect to Factory Settings: step 7, image 1 of 1
    • Disconnect the battery.
  8. How to Reset Your Schlage Connect to Factory Settings: step 8, image 1 of 1
    • Discharge residual electricity by pressing the exterior Schlage button three times on the keypad.
    • Performing this step ensures that any residual electricity left in the battery is removed.
  9. How to Reset Your Schlage Connect to Factory Settings: step 9, image 1 of 3 How to Reset Your Schlage Connect to Factory Settings: step 9, image 2 of 3 How to Reset Your Schlage Connect to Factory Settings: step 9, image 3 of 3
    • Press the Schlage button and continue pressing while at the same time reconnecting the battery.
    • You should see three green check marks on the lock's face.
  10. How to Reset Your Schlage Connect to Factory Settings: step 10, image 1 of 2 How to Reset Your Schlage Connect to Factory Settings: step 10, image 2 of 2
    • Release the button and reattach the battery cover.
  11. How to Reset Your Schlage Connect to Factory Settings: step 11, image 1 of 1
    • Complete the reset procedure by pressing the Schlage button one time.
  12. How to Reset Your Schlage Connect to Factory Settings: step 12, image 1 of 1
    • Enter the original factory's preset user code on the keypad.
    • The bolt will move, and the process is complete once the bolt stops moving.
Finish Line
2 other people completed this guide.
0 Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 79
All Time: 781
