How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable
  1. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable, How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: step 1, image 1 of 2 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable, How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: step 1, image 2 of 2
    • Carefully remove the plastic cover and set aside.
  2. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: step 2, image 1 of 3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: step 2, image 2 of 3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: step 2, image 3 of 3
    • Remove the pad if there is one.
    • Spin the turntable until the belt and drive motor can be seen through a hole.
    • Gently pull the belt off of the motor, and make sure that the belt doesn’t bend or flip over.
    • Take off the turntable platter and set aside.
  3. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: step 3, image 1 of 3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: step 3, image 2 of 3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: step 3, image 3 of 3
    • Remove the single screw from the middle white gear with a Phillips #00 screwdriver.
    • Have a cup or bin so you don’t lose the screw!
    • Gently pull the gear out, revealing the automatic mechanism.
  4. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: step 4, image 1 of 3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: step 4, image 2 of 3 How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: step 4, image 3 of 3
    • Push the metal part away from the center. It should click into place.
    • Push the small metal part back to the center, towards the gear axle.
    • Push the metal part inward, close to the gear’s mounting point.
  5. How to Reset the Automatic Mechanism in an Audio Technica AT-LP60BK Turntable: step 5, image 1 of 1
    • Replace the gear, making sure that the the metal latch on the gear is pushed back.
    • The central shaft should spin freely without hooking the gear.
    • Don't forget to put the band back on the drive motor when reassembling.
0 Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 66
All Time: 2,424
