How to Restore Wool’s Water Resistance
  1. How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: step 1, image 1 of 3 How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: step 1, image 2 of 3 How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: step 1, image 3 of 3
    • Fill a bowl with water at room temperature (20 °C or 68 °F).
    • Use 2 L of water per 200 g of wool.
  2. How to Restore Wool’s Water Resistance: step 2, image 1 of 1
    • Add 1/2 teaspoon of wool wash per 2 L of water.
  3. How to Restore Wool’s Water Resistance: step 3, image 1 of 2 How to Restore Wool’s Water Resistance: step 3, image 2 of 2
    • Insert the articles into the bowl and let soak for 30 minutes.
    • Carefully squeeze the items to allow absorption of soap and water through the wool fibres.
  4. How to Restore Wool’s Water Resistance: step 4, image 1 of 1
    • Lift the items out of the water and gently squeeze to remove excess water and soap.
  5. How to Restore Wool’s Water Resistance: step 5, image 1 of 1
    • Refill the bowl with room temperature water.
    • Use the same volume of water as in Step 1.
  6. How to Restore Wool’s Water Resistance: step 6, image 1 of 2 How to Restore Wool’s Water Resistance: step 6, image 2 of 2
    • Mix 4 tablespoons of emulsified lanolin into 2 liters of water.
  7. How to Restore Wool’s Water Resistance: step 7, image 1 of 2 How to Restore Wool’s Water Resistance: step 7, image 2 of 2
    • Add the articles and squeeze to saturate.
    • Weight the articles with a heavy glass or a dish.
    • Leave to soak for 30 minutes.
  8. How to Restore Wool’s Water Resistance: step 8, image 1 of 2 How to Restore Wool’s Water Resistance: step 8, image 2 of 2
    • Pull the articles out of the lanolin bath and gently squeeze out excess water.
  9. How to Restore Wool’s Water Resistance: step 9, image 1 of 1
    • Lay flat to dry with a clean towel beneath the items.
    • Do not line dry. It can cause wool to stretch and lose shape.
    • Avoid direct sunlight or direct heat when drying.
Finish Line
Yuliya S
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 15
All Time: 532
