How to Reupholster a Bench Cushion
  1. How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: step 1, image 1 of 3 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: step 1, image 2 of 3 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: step 1, image 3 of 3
    • Remove the base from the frame of the bench.
    • If the base is screwed on the frame, use a screwdriver or a drill to remove the screws.
  2. How to Reupholster a Bench Cushion: step 2, image 1 of 3 How to Reupholster a Bench Cushion: step 2, image 2 of 3 How to Reupholster a Bench Cushion: step 2, image 3 of 3
    • Lift the staples with the flathead screwdriver before going in with the pliers.
  3. How to Reupholster a Bench Cushion: step 3, image 1 of 3 How to Reupholster a Bench Cushion: step 3, image 2 of 3 How to Reupholster a Bench Cushion: step 3, image 3 of 3
    • Use a pair of pliers to grip the staples.
    • Twist and pull the staples to remove them from the bench.
  4. How to Reupholster a Bench Cushion: step 4, image 1 of 3 How to Reupholster a Bench Cushion: step 4, image 2 of 3 How to Reupholster a Bench Cushion: step 4, image 3 of 3
    • Place clean material down so the new fabric does not get dirty.
    • Place the fabric with the design face down on top of the clean sheet.
    • Then place the cushion, then the base face down.
  5. How to Reupholster a Bench Cushion: step 5, image 1 of 3 How to Reupholster a Bench Cushion: step 5, image 2 of 3 How to Reupholster a Bench Cushion: step 5, image 3 of 3
    • Keep the safety lock closed when not using the staple gun.
    • When ready to use the staple gun, pull the safety lock down.
    • Insert the staples into the stapler.
  6. How to Reupholster a Bench Cushion: step 6, image 1 of 3 How to Reupholster a Bench Cushion: step 6, image 2 of 3 How to Reupholster a Bench Cushion: step 6, image 3 of 3
    • Pull the fabric taut and staple every 4 inches.
  7. How to Reupholster a Bench Cushion: step 7, image 1 of 3 How to Reupholster a Bench Cushion: step 7, image 2 of 3 How to Reupholster a Bench Cushion: step 7, image 3 of 3
    • Fold the corners of the fabric inward then on top.
    • Staple the fabric down twice for each corner.
    • Cut the excess fabric along the shorter sides of the base length.
    • Place the base back onto the frame.
    • If any screws were removed, screw them back on.
Finish Line
2 other people completed this guide.
Xochitl Vara
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 458
