How to Run MirageOS on TI-NSpire
  1. How to Run MirageOS on TI-NSpire, How to Run MirageOS on TI-NSpire: step 1, image 1 of 2 How to Run MirageOS on TI-NSpire, How to Run MirageOS on TI-NSpire: step 1, image 2 of 2
    • Download the latest version of MirageOS and the latest version of MOSPATCH onto your computer.
    • And if you do not already have it, the TI-NSpire connectivity software.
    • Save the files in a place you can access easily, preferably the desktop.
  2. How to Run MirageOS on TI-NSpire: step 2, image 1 of 1
    • Connect your TI-NSpire to your computer using the TI Calculator Link Cable.
  3. How to Run MirageOS on TI-NSpire: step 3, image 1 of 2 How to Run MirageOS on TI-NSpire: step 3, image 2 of 2
    • Open TI Connect and double click "TI DeviceExplorer."
    • A new window named Device Explorer will open.
  4. How to Run MirageOS on TI-NSpire: step 4, image 1 of 2 How to Run MirageOS on TI-NSpire: step 4, image 2 of 2
    • Highlight the files mospatch.zip and mirageos.zip and drag them into the DeviceExplorer window.
  5. How to Run MirageOS on TI-NSpire: step 5, image 1 of 3 How to Run MirageOS on TI-NSpire: step 5, image 2 of 3 How to Run MirageOS on TI-NSpire: step 5, image 3 of 3
    • Now on your calculator, bring up the catalog by pressing 2nd + 0 (catalog).
    • Press the down arrow key to scroll down to the "Asm(" function (the last item) and press "ENTER".
    • Press PRGM, select MOSPATCH using the arrow keys, and press "ENTER".
  6. How to Run MirageOS on TI-NSpire: step 6, image 1 of 2 How to Run MirageOS on TI-NSpire: step 6, image 2 of 2
    • The calculator should now display "Asm(prgmMOSPATCH".
    • Press "ENTER". The calculator will display "DONE" indicating that you can now run MirageOS on your TI-NSpire!
Now that you have MirageOS running on your TI-NSpire, download some games and try them out! http://www.ticalc.org/pub/83plus/asm/gam...
John Baek
31 Reputation
4 Guides authored
Cal Poly, Team 7-52, Forte Fall 2012 Member of Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Members
12 Guides authored
2 Comments
show an example of running a game. and is the 84 keypad required?
trogfield - Reply
it did not work for me can you help me fix that problem because ive been progaming my own and it did not work so can you find another way because im a big fan of your work it helps me alot
David Fife - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 21
All Time: 2,481
