How to Secure a Hook and Eye Fastener Properly
  1. How to Secure a Hook and Eye Fastener Properly, How to Secure a Hook and Eye Fastener Properly: step 1, image 1 of 1
    • Cut about 28 inches of thread and fold it in half which would be one loop and the two ends together.
    • Then thread the two ends through the eye of the needle.
  2. How to Secure a Hook and Eye Fastener Properly: step 2, image 1 of 2 How to Secure a Hook and Eye Fastener Properly: step 2, image 2 of 2
    • Slide the needle down the thread until you reach about two inches from the loop.
    • Position the needle between the loop and pull through.
    • This will create a knot at the base of the needle which will make the thread less tangled.
    • Next, pull on both ends of the thread to make them equal length before tying a knot.
  3. How to Secure a Hook and Eye Fastener Properly: step 3, image 1 of 1
    • First, position the hook above the zipper and on the inside fabric, about 3mm from the edge.
  4. How to Secure a Hook and Eye Fastener Properly: step 4, image 1 of 2 How to Secure a Hook and Eye Fastener Properly: step 4, image 2 of 2
    • Remove the hook and start by sewing a stitch where your hook was.
    • Then trim the extra thread close to the knot.
  5. How to Secure a Hook and Eye Fastener Properly: step 5, image 1 of 2 How to Secure a Hook and Eye Fastener Properly: step 5, image 2 of 2
    • Sew on top of the knot three times to make sure it is secure.
    • Position the hook on top of the stitch.
    • Anchor the front part of the hook down by sewing over the bottom edge of the hook three times.
  6. How to Secure a Hook and Eye Fastener Properly: step 6, image 1 of 1
    • Then poke the needle underneath the fabric and bring it up in one of the holes.
  7. How to Secure a Hook and Eye Fastener Properly: step 7, image 1 of 2 How to Secure a Hook and Eye Fastener Properly: step 7, image 2 of 2
    • Now hold the other eye of the hook in place.
    • The needle is going to go in from the outside of the wired edge to inside the circle and pull that through till you get a small loop.
    • After that push, the needle through that loop and pull which create a small knot.
    • Now repeat this stitch two more times.
  8. How to Secure a Hook and Eye Fastener Properly: step 8, image 1 of 1
    • Then take the needle into the other hole, coming up in the center.
  9. How to Secure a Hook and Eye Fastener Properly: step 9, image 1 of 1
    • Then repeat step 7 for this hole.
  10. How to Secure a Hook and Eye Fastener Properly: step 10, image 1 of 1
    • After this, tie a knot.
    • Then cut the thread and tie a knot at the end of the thread.
  11. How to Secure a Hook and Eye Fastener Properly: step 11, image 1 of 1
    • To position the eyes, place the hook and eyes together and line up the fabric so the edges match.
  12. How to Secure a Hook and Eye Fastener Properly: step 12, image 1 of 2 How to Secure a Hook and Eye Fastener Properly: step 12, image 2 of 2
    • Hold it in place with your fingers. Start by stitching across the wire and trim the tail near the knot.
    • Sew on top of the knot and the wire three times to make sure it is secure.
    • Making sure you come out from the middle of the eyes.
  13. How to Secure a Hook and Eye Fastener Properly: step 13, image 1 of 1
    • After this, repeat step 7.
  14. How to Secure a Hook and Eye Fastener Properly: step 14, image 1 of 2 How to Secure a Hook and Eye Fastener Properly: step 14, image 2 of 2
    • Then repeat step 8 and 9.
    • It should look like this at the end.
Finish Line
Cecilia
229 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 84
All Time: 1,036
