Introduction
Using a kinked jump rope for exercise can be a bit uncomfortable, but did you know there is a quick fix? To get you jumping smoothly again, we will show you step by step how to straighten it. Let's dive in and fix that rope!
Fill the bucket with hot water and gently insert the jump rope.
Leave it fully submerged for 3 minutes.
Tip: The hot water might cool down so it is always better to have backup water in a kettle to keep refilling the bucket.
Use a spoon to remove the jump rope from the water.
Tip: Avoid touching the water as it might still be hot.
Put the rope under your foot and press it against the floor.
Pull the rope upwards in a straight and vertical motion, following the green arrow.
Hold onto the grips and firmly push the rope upwards following the red arrows.
Keep on holding the rope tight for 3 minutes.
🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
