Introduction
If your Epson ET-2760 printer is not printing complete lines and is having trouble printing a full color image, use this procedure to manually unclog the printhead.
The printhead supplies and transfers the ink onto the paper into the correct form for whatever is being printed, so before beginning, perform a head cleaning or a power cleaning to make sure that the issue must be dealt with manually. From here, the guide can be started following the steps below.
All of the following steps are easy to perform and require no prior skills. However, there is a chance that ink could get on one’s hands and clothes, so don't wear your favorite shirt!
Begin a print of any kind, or a nozzle check.
Once the print has begun, pull the power cable out mid-print.
Enjoy your clean printhead!
12 other people completed this guide.
25 Comments
Simple but to the point tutorial that detailed every step including the tools and supplies needed. Photos helped tremendously too. Thank you.
Where do I find out the "manufacturer's recommended amount of solution" per flush?
Usually it's 5ml
