How to Wire a RJ-45 KeyStone Jack
  1. How to Wire a RJ-45 KeyStone Jack, How to Wire a RJ-45 KeyStone Jack: step 1, image 1 of 3 How to Wire a RJ-45 KeyStone Jack, How to Wire a RJ-45 KeyStone Jack: step 1, image 2 of 3 How to Wire a RJ-45 KeyStone Jack, How to Wire a RJ-45 KeyStone Jack: step 1, image 3 of 3
  2. How to Wire a RJ-45 KeyStone Jack: step 2, image 1 of 3 How to Wire a RJ-45 KeyStone Jack: step 2, image 2 of 3 How to Wire a RJ-45 KeyStone Jack: step 2, image 3 of 3
    • Use your wire stripper to cut the outer sheath
    • Do Not Rotate more than 3-4 times as it will cut the wires underneath.
    • when the length of exposed wires are at a decent length (a little less than a thumbs length) separate the wires by color.
  3. How to Wire a RJ-45 KeyStone Jack: step 3, image 1 of 3 How to Wire a RJ-45 KeyStone Jack: step 3, image 2 of 3 How to Wire a RJ-45 KeyStone Jack: step 3, image 3 of 3
    • on the keystone jack you will see colors. line the wires up to the corresponding colors (white blue - blue, white orange - orange, etc.)
    • use the punchdown tool with the longer side of the blade on the outside to punch the wires in and it will cut off the excess.
    • repeat for each color
  4. How to Wire a RJ-45 KeyStone Jack: step 4, image 1 of 3 How to Wire a RJ-45 KeyStone Jack: step 4, image 2 of 3 How to Wire a RJ-45 KeyStone Jack: step 4, image 3 of 3
    • open up your mounting box
    • there should be a frame for your jack to snap into
  5. How to Wire a RJ-45 KeyStone Jack: step 5, image 1 of 2 How to Wire a RJ-45 KeyStone Jack: step 5, image 2 of 2
    • place the jack into the mounting box, there should be places for zip ties to hold the cable in place
    • place the cover on top and you are done with your cable!
    • test the line using a cable tester.
Make Sure to test with a cable tester
6 other people completed this guide.
Samuel Lynch
281 Reputation
1 Guide authored
Sams TechRepair Member of Sams TechRepair
Business
1 Member
4 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 62
Past 30 Days: 378
All Time: 17,787
