How to align Razor A steering
  1. How to align Razor A steering, How to align Razor A steering: step 1, image 1 of 3 How to align Razor A steering, How to align Razor A steering: step 1, image 2 of 3 How to align Razor A steering, How to align Razor A steering: step 1, image 3 of 3
    • Locate the collar clamp near the base of the steering column.
    • Insert a 3/16" Allen wrench into the screw in the collar clamp and loosen it.
    • The collar clamp will be free to move and may slide around the steering column. When reassembling, return it to its original position.
  2. How to align Razor A steering: step 2, image 1 of 2 How to align Razor A steering: step 2, image 2 of 2
    • Firmly grasp the steering column and turn the wheel by hand.
    • View the scooter along the steering column. Be sure the wheel is perpendicular to the handlebars.
    • The second picture above shows a correct alignment of the steering column from this view.
Finish Line
17 other people completed this guide.
Jordyn
565 Reputation
5 Guides authored
Cal Poly, Team 9-13, Amido Fall 2012 Member of Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Members
10 Guides authored
4 Guide Comments
This is so unhelpful.
Linh Tran - Reply
Great guide! Thanks so much helped me to fix my old scooter and save approx. $50
Max Kittens - Reply
Wow, fixed all the kids scooters on the block….THANK YOU!!!!!
Kathy Earhart - Reply
It worked for me for a little, but after a while the fix stopped working and i am back to where i started, and it is now as tight as it will go. They should really make the scooters better. The guide was really helpful, so thanks so much!
Alan Weinberg - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 41
All Time: 31,397
