How to attach iMac (2012-2020) display using magnets
  1. How to attach iMac (2012-2020) display using magnets, Locate steel bracket at inside top of display: step 1, image 1 of 1
    • The top of the display has a metal bracket that is magnetic.This is where we can attach our magnet. Make sure the position doesn't interfere with closing the screen into the case.The safest method is to use magnets that have 3M tape pads.
  2. How to attach iMac (2012-2020) display using magnets, Attach one 20mm Neodymium magnet on either side: step 2, image 1 of 1
    • Metal bracket with 20mm neodymium magnet attached without adhesive. It attaches strongly.
  3. How to attach iMac (2012-2020) display using magnets, Attach matching magnets on either side: step 3, image 1 of 1
    • With two magnets attached to the interior display bracket on both sides of the display you can carefully swing the display closed and place another 20mm neodymium magnet on the back of the case. It will find the strongest position on its own. You are welcome to mark this position with a pencil and permanently attach the magnet there or leave as is.
  4. How to attach iMac (2012-2020) display using magnets, Close display case and tape bottom of display: step 4, image 1 of 1
    • To secure the bottom of the screen you can use a long strip of black tape or leave as is. You could also make a hinge of tape and mount it internally. You could also use a strip of 3M VHB tape
    • Done.
Finish Line
3 other people completed this guide.
3 Comments
Well done. Do you have a link you can share for the supplier of these magnets?
Alfred - Reply
Hi again, also how thick is the 3/4 inch magnet that you used for both the inside and outside of the case?
Alfred - Reply
Yeah cool! Please, do you have further details of the magnet dimensions?
Daniele Fior - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 21
All Time: 461
