How to check Magnavox MWD200F fuses
  1. How to check Magnavox MWD200F fuses, Faceplate: step 1, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
  2. How to check Magnavox MWD200F fuses: step 2, image 1 of 1
    • Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
  3. How to check Magnavox MWD200F fuses: step 3, image 1 of 1
    • Unclip the three latches on the bottom of the device.
  4. How to check Magnavox MWD200F fuses: step 4, image 1 of 1
    • Pull the faceplate off.
  5. How to check Magnavox MWD200F fuses, How to check Magnavox MWD200F fuses: step 5, image 1 of 1
    • Now that the device is open, you can check for any blown fuses that may need to be replaced.
Taryn
109 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,021
