How to clean Magnavox MWD200F gears
  1. How to clean Magnavox MWD200F gears, Faceplate: step 1, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
  2. How to clean Magnavox MWD200F gears: step 2, image 1 of 1
    • Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
  3. How to clean Magnavox MWD200F gears: step 3, image 1 of 1
    • Unclip the three latches on the bottom of the device.
  4. How to clean Magnavox MWD200F gears: step 4, image 1 of 1
    • Pull the faceplate off.
  5. How to clean Magnavox MWD200F gears, Disk Drive: step 5, image 1 of 2 How to clean Magnavox MWD200F gears, Disk Drive: step 5, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the two screws at the base of the disk drive.
  6. How to clean Magnavox MWD200F gears: step 6, image 1 of 2 How to clean Magnavox MWD200F gears: step 6, image 2 of 2
    • Use the screwdriver to remove two screws on either side of the silver security bar.
  7. How to clean Magnavox MWD200F gears: step 7, image 1 of 2 How to clean Magnavox MWD200F gears: step 7, image 2 of 2
    • Pull out the silver security bar and set aside.
  8. How to clean Magnavox MWD200F gears: step 8, image 1 of 1
    • Take out the two screws on either side of the green circuit board.
  9. How to clean Magnavox MWD200F gears: step 9, image 1 of 2 How to clean Magnavox MWD200F gears: step 9, image 2 of 2
    • Carefully lift the board just enough to remove the disk drive.
  10. How to clean Magnavox MWD200F gears: step 10, image 1 of 3 How to clean Magnavox MWD200F gears: step 10, image 2 of 3 How to clean Magnavox MWD200F gears: step 10, image 3 of 3
    • Remove the two screws at the back of the disk drive.
  11. How to clean Magnavox MWD200F gears: step 11, image 1 of 2 How to clean Magnavox MWD200F gears: step 11, image 2 of 2
    • Gently lift the disk drive out of the DVD player.
    • The disk drive is still attached but you are now able to get to underneath it for cleaning and maintenance.
  12. How to clean Magnavox MWD200F gears, How to clean Magnavox MWD200F gears: step 12, image 1 of 2 How to clean Magnavox MWD200F gears, How to clean Magnavox MWD200F gears: step 12, image 2 of 2
    • Turn disc drive over so you can see the gears on the bottom.
  13. How to clean Magnavox MWD200F gears: step 13, image 1 of 2 How to clean Magnavox MWD200F gears: step 13, image 2 of 2
    • Using a cotton swap or a cleansing cloth and alcohol, gently rub the gears ridding of any debris and dust.
    • You can also use a compressed air can as well. Just point the nozzle at the gears and spray with the compressed air.
2 other people completed this guide.
Taryn
109 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 840
