How to clean TI-Nspire buttons
  1. How to clean TI-Nspire buttons, How to clean TI-Nspire buttons: step 1, image 1 of 1
    • Turn the calculator over so that the blue Texas Instruments logo is up.
    • Slide the blue case downward until it is completely removed from the calculator.
  2. How to clean TI-Nspire buttons: step 2, image 1 of 1
    • Step 2 and 3 to detach the keyboard are optional, but may prevent permanent damage to the calculator.
    • Turn the calculator over and locate the sliding latch on the back of the calculator.
  3. How to clean TI-Nspire buttons: step 3, image 1 of 2 How to clean TI-Nspire buttons: step 3, image 2 of 2
    • At the same time, slide the latch to the right and pull the keypad downward. This should completely separate the keypad from the calculator.
  4. How to clean TI-Nspire buttons: step 4, image 1 of 1
    • Now that you have detached the keypad, gather the cotton swabs and rubbing alcohol.
    • Dampen a cotton swab by placing 1 to 3 drops of rubbing alcohol on the tip.
    • Be careful not to completely soak the the cotton swab with the rubbing alcohol.
    • DO NOT pour the rubbing alcohol directly onto the keypad. Too much liquid exposure can permanently damage it.
  5. How to clean TI-Nspire buttons: step 5, image 1 of 1
    • Use the moistened cotton swab and rub it around each button, in crevices, and anywhere on the keypad that may have dirt. Replace the swab as often as desired.
    • Keep the rubbing alcohol away from the calculator's visual display. Water exposure to the screen can permanently damage the screen.
Now your buttons should be free of any stickiness.
Mariel Sanchez
22 Reputation
2 Guides authored
Cal Poly, Team 7-52, Forte Fall 2012 Member of Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 17
All Time: 5,699
