How to clean the CONDOR L130I3E fan
Video Overview
  1. How to clean the CONDOR L130I3E fan, How to clean the CONDOR L130I3E fan: step 1, image 1 of 3 How to clean the CONDOR L130I3E fan, How to clean the CONDOR L130I3E fan: step 1, image 2 of 3 How to clean the CONDOR L130I3E fan, How to clean the CONDOR L130I3E fan: step 1, image 3 of 3
    • First of all, make sure your device is switched off and unplugged.
    • Remove the battery by pulling the two screws in the direction indicated by the pins.
    • Pull the battery up.
  2. How to clean the CONDOR L130I3E fan: step 2, image 1 of 3 How to clean the CONDOR L130I3E fan: step 2, image 2 of 3 How to clean the CONDOR L130I3E fan: step 2, image 3 of 3
    • To remove the hard drive, unplug its screws in this cover.
    • Pull the hard drive in the direction indicated to remove it.
    • Then we remove the hard drive from its place with ease.
  3. How to clean the CONDOR L130I3E fan: step 3, image 1 of 3 How to clean the CONDOR L130I3E fan: step 3, image 2 of 3 How to clean the CONDOR L130I3E fan: step 3, image 3 of 3
    • To access the motherboard, you must first remove the keyboard because underneath it screws should be removed to separate the base of the chassis from the top of the keyboard.
    • With a flat screwdriver we remove the keyboard by pressing the red-pointed component and pushing the keyboard up to release it.
  4. How to clean the CONDOR L130I3E fan: step 4, image 1 of 2 How to clean the CONDOR L130I3E fan: step 4, image 2 of 2
    • Remove the keyboard connector from the motherboard
    • Keyboard is now removed successfully
  5. How to clean the CONDOR L130I3E fan: step 5, image 1 of 3 How to clean the CONDOR L130I3E fan: step 5, image 2 of 3 How to clean the CONDOR L130I3E fan: step 5, image 3 of 3
    • Remove the top cover and remove the processor cooling fan.
    • Unscrew the screws indicated in red to remove the cooling fan.
    • Remove the fan.
  6. How to clean the CONDOR L130I3E fan: step 6, image 1 of 1
    • We now clean and remove the dust and sediments that hinder fan function and increase processor heat.
6 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
AMOUR nasreddine
1,128 Reputation
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 908
