How to clean the Pentax PZ-10 gears
  1. How to clean the Pentax PZ-10 gears, Removing the Bottom Cover Screws: step 1, image 1 of 2 How to clean the Pentax PZ-10 gears, Removing the Bottom Cover Screws: step 1, image 2 of 2
    • Place the lens face up to locate the bottom cover.
    • Remove the two 7mm screws using a J0 screwdriver.
    • Remove the six 4.3 mm screws using a J0 screwdriver.
  2. How to clean the Pentax PZ-10 gears, Removing the Bottom Cover: step 2, image 1 of 1
    • After the screws are removed, the bottom cover should easily pry off.
  3. How to clean the Pentax PZ-10 gears, Accessing Gears: step 3, image 1 of 2 How to clean the Pentax PZ-10 gears, Accessing Gears: step 3, image 2 of 2
    • Using a J0 screwdriver, remove the 4mm screw holding the metal plate to expose the gears.
  4. How to clean the Pentax PZ-10 gears, Removing Gear Housing Plate: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Using a pair of tweezers, gently remove the metal plate covering the gears.
    • Part of the plate's tab fits into a socket. Try to pivot around it when removing the plate to prevent bending the plate.
    • Be careful with the gears because some may be loose.
  5. How to clean the Pentax PZ-10 gears, Cleaning the Gears: step 5, image 1 of 2 How to clean the Pentax PZ-10 gears, Cleaning the Gears: step 5, image 2 of 2
    • Use tweezers to rotate gears or remove any large particles obstructing their rotation.
    • Smaller particles can be cleared using a microfiber cloth only. Other fabrics may leave residual fibers.
Bryan Sugiarto
252 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 14
All Time: 903
