How to clean the Samsung SGH-E317 keypad
  1. How to clean the Samsung SGH-E317 keypad, Battery: step 1, image 1 of 1
    • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • You may want to use a plastic opening tool to help pry the back panel off.
  2. How to clean the Samsung SGH-E317 keypad, Motherboard: step 2, image 1 of 1
    • Unscrew the four 4.5mm screws located on the back plate.
  3. How to clean the Samsung SGH-E317 keypad: step 3, image 1 of 1
    • Remove the rubber screw cover using your fingernail.
  4. How to clean the Samsung SGH-E317 keypad: step 4, image 1 of 1
    • Unscrew the 4.5mm screw located underneath the rubber cover.
  5. How to clean the Samsung SGH-E317 keypad: step 5, image 1 of 1
    • Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
    • The panel should come off without much effort.
  6. How to clean the Samsung SGH-E317 keypad: step 6, image 1 of 1
    • With the back panel removed, the motherboard should be fully exposed.
  7. How to clean the Samsung SGH-E317 keypad: step 7, image 1 of 2 How to clean the Samsung SGH-E317 keypad: step 7, image 2 of 2
    • Remove the camera and volume buttons and place them in a safe spot until reassembly.
  8. How to clean the Samsung SGH-E317 keypad: step 8, image 1 of 2 How to clean the Samsung SGH-E317 keypad: step 8, image 2 of 2
    • Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
  9. How to clean the Samsung SGH-E317 keypad: step 9, image 1 of 2 How to clean the Samsung SGH-E317 keypad: step 9, image 2 of 2
    • Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
  10. How to clean the Samsung SGH-E317 keypad, How to clean the Samsung SGH-E317 keypad: step 10, image 1 of 1
    • After removing motherboard, the phone will look like this.
  11. How to clean the Samsung SGH-E317 keypad: step 11, image 1 of 1
    • Grab the corner of the rubber key pad and lift out slowly.
  12. How to clean the Samsung SGH-E317 keypad: step 12, image 1 of 2 How to clean the Samsung SGH-E317 keypad: step 12, image 2 of 2
    • By using a small standard screwdriver and a fine, thin, soft cloth you can clean in between the keypad to remove dirt and debris.
Joe Cavaletto
101 Reputation
1 Guide authored
Cal Poly, Team 11-23, Maness Winter 2011 Member of Cal Poly, Team 11-23, Maness Winter 2011
CPSU-MANESS-W11S11G23
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 967
