How to clean your Panasonic SA-HT810V VCR heads
  1. How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: step 1, image 1 of 3 How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: step 1, image 2 of 3 How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: step 1, image 3 of 3
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. How to clean your Panasonic SA-HT810V VCR heads: step 2, image 1 of 2 How to clean your Panasonic SA-HT810V VCR heads: step 2, image 2 of 2
    • Rotate the device so that the back faces you.
    • With a phillips head screwdriver, locate and remove the 12 screws highlighted by the red circles in image one.
  3. How to clean your Panasonic SA-HT810V VCR heads: step 3, image 1 of 1
    • Before removing cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. How to clean your Panasonic SA-HT810V VCR heads: step 4, image 1 of 3 How to clean your Panasonic SA-HT810V VCR heads: step 4, image 2 of 3 How to clean your Panasonic SA-HT810V VCR heads: step 4, image 3 of 3
    Tool used on this step:
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • Before cleaning the VCR heads, be sure that the front of the device is facing you with the top cover removed.
    • Locate the two VCR heads highlighted in by the blue boxes in image one.
    • GENTLY clean heads with a microfiber rag and a cleaning solution of your choice.
2 other people completed this guide.
Nathan Cheadle
161 Reputation
7 Guides authored
Cal Poly, Team 16-5, Maness Spring 2010 Member of Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 2,735
