How to clear Lexmark Intuition S505 paper jam
  1. How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: step 1, image 1 of 2 How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: step 1, image 2 of 2
    • Lift the scanning unit.
  2. How to clear Lexmark Intuition S505 paper jam: step 2, image 1 of 2 How to clear Lexmark Intuition S505 paper jam: step 2, image 2 of 2
    • Check the duplex unit, located at the rear of the printer, for any paper obstruction. Pinch the top button to remove the unit.
  3. How to clear Lexmark Intuition S505 paper jam: step 3, image 1 of 1
    • If there is any paper stuck inside, remove it. If not, snap the unit back onto the printer.
  4. How to clear Lexmark Intuition S505 paper jam: step 4, image 1 of 1
    • Check the front slot, which is located underneath the LED display. If there is any paper, remove it.
Once the paper obstruction is removed, your printer should print smoothly without any problems.
2 other people completed this guide.
Omar
111 Reputation
2 Guides authored
Cal Poly, Team 18-38, Regan Winter 2013 Member of Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Members
8 Guides authored
One Comment
Mine still says paper jam but there's no paper stuck in it all. Can you suggest other probs and solutions?
Debra Collis (Debbie) - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 1,664
