How to connect Samsung GT-C3750 to a PC via Samsung Kies
  1. How to connect Samsung GT-C3750 to a PC via Samsung Kies, Downloading and Installing: step 1, image 1 of 1
    • Phones like this one use a program called Samsung Kies to connect to a PC.
    • Go to https://www.samsung.com/levant/support/k... , download and install the program.
    • If you face any problems opening the file, try launching a CMD window with admin privileges and paste the file path there, so the installer launches this way.
  2. How to connect Samsung GT-C3750 to a PC via Samsung Kies, Installation Wizard: step 2, image 1 of 1
    • Follow the installation wizard and configure the app as you like.
  3. How to connect Samsung GT-C3750 to a PC via Samsung Kies, Update: step 3, image 1 of 1
    • You may have to update the program.
  4. How to connect Samsung GT-C3750 to a PC via Samsung Kies, Phone Configuration: step 4, image 1 of 3 How to connect Samsung GT-C3750 to a PC via Samsung Kies, Phone Configuration: step 4, image 2 of 3 How to connect Samsung GT-C3750 to a PC via Samsung Kies, Phone Configuration: step 4, image 3 of 3
    • From the main menu, go to Settings,
    • Then select the 8th option "PC connections",
    • Finally, select the option "Samsung Kies".
    • Don't forget to connect the phone to the PC via a micro USB cable.
  5. How to connect Samsung GT-C3750 to a PC via Samsung Kies, Final Steps: step 5, image 1 of 2 How to connect Samsung GT-C3750 to a PC via Samsung Kies, Final Steps: step 5, image 2 of 2
    • While the phone is connecting, you will see this screen.
    • Lastly, you have finally connected your phone successfully to your PC! Explore your options via Samsung Kies!
Close to program and disconnect your device.
GK_
376 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 81
