How to create a Tails Live USB
  1. How to create a Tails Live USB, Download Tails OS: step 1, image 1 of 2 How to create a Tails Live USB, Download Tails OS: step 1, image 2 of 2
  2. How to create a Tails Live USB, Download and install BalenaEtcher: step 2, image 1 of 1
    • Insert the USB flash drive into an available USB port on your computer and launch Etcher.
    • In Etcher, click "Flash from file" and select the Tails ISO image you downloaded earlier.
    • Select the USB flash drive as the target device.
    • Double-check to ensure you have selected the correct drive, as the process will erase all data on the selected drive.
    • Click "Flash!" to start the process. Etcher will copy the Tails OS to the USB drive.
    • Once the flashing process is complete, safely eject the USB drive from your computer.
    • Etcher should do this automatically, however it is still good practice to check that the drive was ejected properly.
    • Insert the Tails live USB into the computer you want to use.
    • Restart the computer and enter the boot menu by pressing the appropriate key during startup (usually F2, F12, or Delete).
    • Select the USB drive as the boot device from the boot menu.
    • Tails will start, and you'll be presented with the Tails Greeter screen.
    • Follow the on-screen instructions to configure language, keyboard, and other settings.
    • Once completed you will be able to use your computer in a secure and private live environment. Your online activities are routed through the Tor network for anonymity.
Creating a Tails live USB using this iFixit guide provides you with a secure and private way to use Tails OS on any computer without leaving traces. Remember to always use Tails responsibly and respect the privacy and security it offers.
7 other people completed this guide.
Jacob Mehnert
45,686 Reputation
51 Guides authored
iFanatics Member of iFanatics
Community
65 Members
220 Guides authored
0 Guide Comments
Past 24 Hours: 43
Past 7 Days: 358
Past 30 Days: 1,446
All Time: 21,254
