How to determine the cause for a restart in Kali Linux
    • Press Ctrl + Alt + T to open the Terminal Interface.
    • Enter the command sudo mkdir /var/log/journal
    • Enter the command: sudo systemd-tmpfiles --create --prefix /var/log/journal 2>/dev/null
    • sudo systemctl -s SIGUSR1 kill systemd-journald
    • Once this command is run, you will need to restart your machine to get your current system logs.
    • See your logged boots from your journal with the following: journalctl --list-boots
    • Locate a specific reboot using this command: journalctl -b {num} -n
Optionally you can use killall -USR1 systemd-journald rather than restarting your services. This way a user can keep all the logging from the current session.
Jacob Mehnert
28,759 Reputation
43 Guides authored
iFanatics Member of iFanatics
Community
55 Members
159 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 905
