How to fix Leaks in Shower Tiles by Caulking
  1. How to fix Leaks in Shower Tiles by Caulking, How to fix Leaks in Shower Tiles by Caulking: step 1, image 1 of 3 How to fix Leaks in Shower Tiles by Caulking, How to fix Leaks in Shower Tiles by Caulking: step 1, image 2 of 3 How to fix Leaks in Shower Tiles by Caulking, How to fix Leaks in Shower Tiles by Caulking: step 1, image 3 of 3
    • Using a putty knife, remove the old caulk from the surface.
    • While using the scraper, hold the sharp end away from you.
  2. How to fix Leaks in Shower Tiles by Caulking: step 2, image 1 of 3 How to fix Leaks in Shower Tiles by Caulking: step 2, image 2 of 3 How to fix Leaks in Shower Tiles by Caulking: step 2, image 3 of 3
    • Using a damp cloth, wipe the surface to remove the scraped caulking.
    • Using another cloth, wipe the surface with disinfectant.
  3. How to fix Leaks in Shower Tiles by Caulking: step 3, image 1 of 3 How to fix Leaks in Shower Tiles by Caulking: step 3, image 2 of 3 How to fix Leaks in Shower Tiles by Caulking: step 3, image 3 of 3
    • Place the caulking tube in the caulking gun.
    • Place the back of the tube into the gun.
    • Push the front of the tube inside.
    • Twist the hook at the end of the caulking gun inwards to hold the caulking tube in place.
  4. How to fix Leaks in Shower Tiles by Caulking: step 4, image 1 of 3 How to fix Leaks in Shower Tiles by Caulking: step 4, image 2 of 3 How to fix Leaks in Shower Tiles by Caulking: step 4, image 3 of 3
    • Cut the tip of the caulking tube at an angle.
    • Test the caulk on a paper towel before applying it on the surface.
    • Press the trigger on the caulking gun to release the caulk from the tube.
  5. How to fix Leaks in Shower Tiles by Caulking: step 5, image 1 of 3 How to fix Leaks in Shower Tiles by Caulking: step 5, image 2 of 3 How to fix Leaks in Shower Tiles by Caulking: step 5, image 3 of 3
    • Start caulking at the top of the surface and move down along the surface.
    • Place the tip of the caulking gun on the surface between two tiles and move it down at a steady pace.
    • Go back to the top and apply the caulking on the next tile, until all of the space between the tiles has caulking.
    • Hold the caulking gun with both hands to be steady.
  6. How to fix Leaks in Shower Tiles by Caulking: step 6, image 1 of 3 How to fix Leaks in Shower Tiles by Caulking: step 6, image 2 of 3 How to fix Leaks in Shower Tiles by Caulking: step 6, image 3 of 3
    • Using a damp finger, smoothen the caulking on the surface.
    • Keep a rag nearby to periodically wipe off any excess caulking.
    • Allow the caulking to dry for five minutes, before moving on to the next part.
  7. How to fix Leaks in Shower Tiles by Caulking: step 7, image 1 of 3 How to fix Leaks in Shower Tiles by Caulking: step 7, image 2 of 3 How to fix Leaks in Shower Tiles by Caulking: step 7, image 3 of 3
    • Now, apply the caulking in the horizontal direction.
    • Repeat the process in Step 5 and 6.
    • Allow the caulking to dry for 5 minutes before moving to the next part.
  8. How to fix Leaks in Shower Tiles by Caulking: step 8, image 1 of 2 How to fix Leaks in Shower Tiles by Caulking: step 8, image 2 of 2
    • Go over any areas that were missed or that don't have enough caulking.
    • Put a pea size amount of caulking in that area and smoothen it out with a damp finger.
  9. How to fix Leaks in Shower Tiles by Caulking: step 9, image 1 of 3 How to fix Leaks in Shower Tiles by Caulking: step 9, image 2 of 3 How to fix Leaks in Shower Tiles by Caulking: step 9, image 3 of 3
    • Let the surface dry for 20 minutes.
    • After the caulking has dried, remove the excess using a putty knife.
    • To avoid scratches while removing the excess, lay the scrapper flat towards the surface.
  10. How to fix Leaks in Shower Tiles by Caulking: step 10, image 1 of 2 How to fix Leaks in Shower Tiles by Caulking: step 10, image 2 of 2
    • In case there is still any excess, scrub over the scraped area with a damp cloth.
    • If there is any caulking left over, cover the tip of the caulking tube with a paper towel and store for later use.
    • The caulking tube can be left in the caulking gun or taken out by performing step 4 backward.
Clean the surface and completely let it dry before using it. It may take up to a full day to dry completely, so be prepared to not use the surface for a while!
Suman Grewal
208 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 27
All Time: 1,358
