How to fix Mobee Magic Mouse disconnection issues
Video Instructions
Finish Line
31 other people completed this guide.
Peter Barnett
759 Reputation
1 Guide authored
5 Guide Comments
I disassembled the Mobee battery pack by removing the 2 tiny screws holding the battery-cover together. One of the batteries had both poles covered with small pieces of greyish tape. Looked like someone forgot to remove them at assembly. I removed the tape. Works well now.
Leuk
BEANTWOORDEN
YatLok Mok - Reply
I thought I had to buy a new mouse until I found this. Foil proved it. Now for the permanent fix with the solder! Thank you.
Steve Gilbert - Reply
The batteries inside the mobee are AAA, not AA. I replaced them some time ago :)
Arjen Gerstel - Reply
I use regular rechargeable batteries, not Mobee ones, but also had a lot of random disconnects. Had read all I could find on the subject but no luck. Finally understood that the problem is on the pointy end of the batteries! So far so good, no more disconnects! Thank you!
cazumanc - Reply
What is the screw type and size for the Magic Mouse battery pack? They're so small I can barely see them! Are they tiny Allen/Hex heads?
Jeffrey Powell - Reply
Past 24 Hours: 6
Past 7 Days: 38
Past 30 Days: 157
All Time: 40,624
