How to fix Nikon D3000 shutter release button error
  1. How to fix Nikon D3000 shutter release button error, How to fix Nikon D3000 shutter release button error: step 1, image 1 of 2 How to fix Nikon D3000 shutter release button error, How to fix Nikon D3000 shutter release button error: step 1, image 2 of 2
    • Remove six 3 mm x 2.5 mm Phillips head screws from the bottom right back of the camera bottom.
    • Remove three 3 mm x 5.5 mm from the bottom left of the camera bottom.
    • Lift the battery cover and remove two 3 mm x 5.5 mm screws from the bottom left of the camera.
    • Remove the screws from the bottom of the case to access the shutter gear.
  2. How to fix Nikon D3000 shutter release button error: step 2, image 1 of 2 How to fix Nikon D3000 shutter release button error: step 2, image 2 of 2
    • The second picture shows the bottom plate removed, but this is not necessary and requires intensive disassembling of the camera.
    • Blow out the red gear wheel to clean the wheel from any possible dust or debris.
    • Lubricate the red wheel to lessen the stiffness of the wheel's motion and rotate with the black plastic prying tool.
11 other people completed this guide.
Josh
331 Reputation
1 Guide authored
USF Tampa, Team 14-7, Meier Fall 2015 Member of USF Tampa, Team 14-7, Meier Fall 2015
USFT-MEIER-F15S14G7
4 Members
6 Guides authored
2 Guide Comments
I have a d3200 that “at will” will throw this message, so incredibly random. It will be fine then …. the message. Always at the worst moment. I have checked the mirror path and that doesn’t seem to be catching at all. I think I want to try this fix you outlined, but I have. D3200 not a 3000… is everything the same?
MARY M DUNNIGAN - Reply
Hello there.
I attempt many times to resolve issue on my camera. I tried lubricate red gear wheel, but problem persisting.
Does any other thing I need to do?
Salvador Diaz - Reply
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 53
All Time: 12,447
