How to fix TC Electronic Level Pilot static noise
  1. How to fix TC Electronic Level Pilot static noise, How to fix TC Electronic Level Pilot static noise: step 1, image 1 of 1
    • The bottom rubber base can be removed
  2. How to fix TC Electronic Level Pilot static noise: step 2, image 1 of 1
    • Spray the small opening there with some multi-purpose oil.
11 other people completed this guide.
Alpha Dimension
388 Reputation
1 Guide authored
6 Comments
Not a good idea. Oil will &&^& it up dah.
stevenowlbassett - Reply
DeOxit (contact cleaner designed specifically for potentiometers) is what most people are recommending, not WD40 or dielectric grease..
Preferably DeOxit Gold, or at least not their (Hosa's) Fader Lube.
mystiphysician - Reply
Yes, use DeOxit or some similar contact cleaner
Eng Wei Chua - Reply
That knob became scratchy after some use. Cramolin contaclean helped, as always. Thanks for the teardown guide.
Daniel Leonov - Reply
Thanks Alpha Dimension for your disassembly guide.
If one needs to change it, it’s a Bourns potentiometer and its complete reference is PTD904-1020K-A103 (I’ve checked with measures on the potentiometer of my Level Pilot and with the PDF reference here : https://www.bourns.com/docs/product-data...)
Hervé HERRY - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 5,710
