How to fix a Karcher WV2 with a green LED blinking quickly
Corentin Kezadri
Corentin Kezadri and 4 other contributors
Last updated on March 26, 2025
10 minutes
Easy
Featured Guide
Grammar Police
Bullets!
Community-Contributed Guide
Introduction
Go to step 1
Do you have a Karcher WV2 window cleaner that refuses to turn on?
Don't Panic!
Follow this step-by-step tutorial to fix your device.
  1. How to fix a Karcher WV2 with a green LED blinking quickly, Check your model: step 1, image 1 of 1
    • First, check that your device is the correct model.
    • Remove the high nozzle.
    • Remove the wastewater tank.
    • Check if your model is WV2.
  2. How to fix a Karcher WV2 with a green LED blinking quickly, Remove the first screws: step 2, image 1 of 1
    • Remove the first five screws using a compatible torx bit or a flat-head screwdriver.
    • There is no specific length for each screw, so it doesn't matter if they get mixed up.
    • Don't use a screwdriver with a shaft that is too large as it could get stuck in the plastic part.
  3. How to fix a Karcher WV2 with a green LED blinking quickly, Remove the bottom cover: step 3, image 1 of 3 How to fix a Karcher WV2 with a green LED blinking quickly, Remove the bottom cover: step 3, image 2 of 3 How to fix a Karcher WV2 with a green LED blinking quickly, Remove the bottom cover: step 3, image 3 of 3
    • Using a flat-head screwdriver, you can carefully remove the bottom cover.
    • There are pins aren’t visible from the outside. You must get them out of the way. This is done by sliding a round tip knife into the groove.
    • (Originally the french text said: Slide a round tip knife between the body and the base at the yellow seal. This seal doesn’t seem to exist.)
    • Do not force in this step, you could break the plastic towers
    • Once the bottom cover is removed, unscrew the last screw located behind the bottom cover.
  4. How to fix a Karcher WV2 with a green LED blinking quickly, Separate the two halves: step 4, image 1 of 2 How to fix a Karcher WV2 with a green LED blinking quickly, Separate the two halves: step 4, image 2 of 2
    • Using a flat-head screwdriver, or gently by hand, separate the two halves, right and left, of the device.
  5. How to fix a Karcher WV2 with a green LED blinking quickly, Remove the suction body assembly: step 5, image 1 of 2 How to fix a Karcher WV2 with a green LED blinking quickly, Remove the suction body assembly: step 5, image 2 of 2
    • Gently remove the suction body and the On/Off button from the housing.
    • With your hand, and without forcing it, gently remove the two lugs on either side of the fan to separate it from the "nozzle".
  6. How to fix a Karcher WV2 with a green LED blinking quickly, Inspect and clean!: step 6, image 1 of 2 How to fix a Karcher WV2 with a green LED blinking quickly, Inspect and clean!: step 6, image 2 of 2
    • Inspect the fan and its shaft. The flashing green light indicates that the fan is unable to start.
    • Rotate the fan by hand to check if there is any resistance.
    • If there isn't anything preventing the fan from spinning, there shouldn't be any resistance.
    • Press the button, your fan should spin again!
  7. How to fix a Karcher WV2 with a green LED blinking quickly, Enjoy your device!: step 7, image 1 of 1
    • You can now take advantage of your window cleaner to clean all of your windows!
To reassemble your device, follow the instructions in reverse order.
16 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating â€ș
Attached Documents
Corentin Kezadri
1,299 Reputation
5 Guides authored
11 Comments
Merci beaucoup pour ce tutoriel.
Je ne sais pas réellement ce qui a bloqué le ventilateur, je l'ai tourné plusieurs fois à la main et d'un coup il a fonctionné de nouveau. Merci encore
Nadine Julien Gatinaud - Reply
Avec grand plaisir ! :)
Parfois les hélices sont bloquées par un micro organisme.
Corentin Kezadri -
Et bien la pouasse! 😟 Merci pour le tuto dĂ©montage / test mais je relance le ventilo tout est ok j’allume impec mais ça s’éteint automatiquement aprĂšs 3/4 secondes , donc ce ne serait pas le problĂšme
LumiĂšre verte clignotante, puis parfois plus du tout , on sent une envie d’y aller mais obligĂ© d’insister sur l’allumage avant que ça ne parte
 je crains que ce ne soit plus sĂ©rieux 😟
Merci de votre aide .
Lety Guillaut - Reply
Merci beaucoup, la garantie de mon appareil finissait en juin et panne début septembre.
J'ai suivi Ă  la lettre votre tuto et c bon.
MĂȘme si je n'ai rien trouvĂ©, sans doute qlq chose de minuscule.
A noter qu'il faut un tournevis étoilé de toute petite taille que je n'avais pas.
Mais je peux Ă  nouveau profiter de l'appareil.
Géraldine Vallée - Reply
Merci pour le tuto, il m'a bien aidé!
Mimi - Reply
Past 24 Hours: 101
Past 7 Days: 797
Past 30 Days: 3,505
All Time: 24,507
