How to fix a Kindle Voyage stuck in a boot loop
  1. How to fix a Kindle Voyage stuck in a boot loop, Back Panel: step 1, image 1 of 2 How to fix a Kindle Voyage stuck in a boot loop, Back Panel: step 1, image 2 of 2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. How to fix a Kindle Voyage stuck in a boot loop: step 2, image 1 of 1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. How to fix a Kindle Voyage stuck in a boot loop: step 3, image 1 of 3 How to fix a Kindle Voyage stuck in a boot loop: step 3, image 2 of 3 How to fix a Kindle Voyage stuck in a boot loop: step 3, image 3 of 3
    • Once the screws are removed, the back panel can slide off the device.
  4. How to fix a Kindle Voyage stuck in a boot loop: step 4, image 1 of 2 How to fix a Kindle Voyage stuck in a boot loop: step 4, image 2 of 2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. How to fix a Kindle Voyage stuck in a boot loop, Remove the motherboard: step 5, image 1 of 1
    • Make sure to remove all connectors, then remove all the screws.
    • You should be able to remove the motherboard from the case.
    • Remove the battery connector first.
  6. How to fix a Kindle Voyage stuck in a boot loop, Solder thin wires to RX, TX, and GND: step 6, image 1 of 1
    • The three wires should go on the pads outlined in red.
    • From left to right, the pins are TX, RX, and GND.
    • If you are finding it difficult to solder to the ground pin, try soldering to one of the shields, which would normally be where the blue outline is.
    • Put the motherboard back into the Kindle, but don't re-connect the battery.
  7. How to fix a Kindle Voyage stuck in a boot loop, Build the circuit on the breadboard and connect the Kindle: step 8, image 1 of 1
    • Using the resistors, diodes, USB serial adapter, and breadboard wires, build this circuit on the breadboard.
    • If you don't know how to use a breadboard, YouTube is a great place to learn.
    • Sorry for the stupid cropping of the image, iFixit doesn't like it. See the full image at https://www.mobileread.com/forums/showth...
    • Then, using alligator clips, connect the wires on the "kindle" side of the schematic to the appropriate wires from the Kindle.
    • Plug your USB serial adapter into the computer.
    • Start your serial terminal program (like Minicom). Make sure to disable "Hardware Flow Control".
  8. How to fix a Kindle Voyage stuck in a boot loop, Connect the Kindle battery and start diagnostic mode: step 10, image 1 of 1
    • Connect the kindle battery.
    • You'll start seeing text in the serial terminal. When it says "Hit any key to stop autoboot" press a key.
    • Type in "bootm 0xE41000 " and press enter.
  9. How to fix a Kindle Voyage stuck in a boot loop, Upload firmware to Kindle: step 11, image 1 of 1
    • Tap "U - USB Export" on the screen.
    • Plug your Kindle into your computer through the Kindle's USB port.
    • Download the Kindle firmware from https://www.amazon.com/gp/help/customer/...
    • Open the Kindle drive on your computer and drag the .bin file into it.
    • Eject your Kindle and unplug it from your computer.
    • Press "Q" either onscreen or in your serial terminal.
    • Tap "Reboot or Disable Diags", or type "D"
    • Tap "Reboot System", or type "R"
  10. How to fix a Kindle Voyage stuck in a boot loop, Flash new firmware: step 12, image 1 of 1
    • The Kindle should now be booting into the regular OS.
    • When the serial terminal says "Press [ENTER] for recovery menu...", press enter.
    • Type "u" and quickly follow that with the enter key.
    • Your kindle will restore the firmware you copied over previously.
    • At the end of this process, your Kindle should be showing its bookshelf screen.
    • Unplug the USB to serial adapter, and remove the wires from the kindle.
    • If your wires are thin enough, you may be able to break them away from the pad, but be careful to not tear the pad off.
    • If you can't do that or just want to be safe, remove the motherboard and desolder the wires, then re-install the motherboard.
To complete the repair, close the device by following the process detailed in the beginning in reverse.
Merlin04
169 Reputation
1 Guide authored
One Comment
Merlin04, you do an excellent job at breaking down the tasks and guiding a person through the process!!
Jennifer Gehman - Reply
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 50
All Time: 2,676
