How to fix a blown heater element in a Toaster
Video Overview
    • Insert wisdom here.
    • how to fix a toaster
Not too difficult, you need patience though.
4 other people completed this guide.
jon
3,012 Reputation
22 Guides authored
2 Comments
this solution worked great for a bout a two weeks, then despite having connectivity in the ribbon, it does not heat up. It sounded like you weren’t expecting your solution to work forever. Did it give out on you after a little bit because of the increased resistance and the crimp?
mitchell.drury - Reply
Mine is still working even after all this time (over 2 years ago). If your heater element is still connected (low resistance) then the fault is somewhere else. Trace the resistance of connections back through the switch to the plug to find the fault.
jon - Reply
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 93
All Time: 25,274
