How to fix a wobbly Sony Ericsson w600i swivel
  1. How to fix a wobbly Sony Ericsson w600i swivel, Back housing: step 1, image 1 of 1
    • Unscrew the four Torx screws from the backplate.
    • The backplate may begin to separate from the keypad face. Do not try to remove it yet.
    • The screws are T5 Torx screws, 5.6mm.
  2. How to fix a wobbly Sony Ericsson w600i swivel: step 2, image 1 of 1
    • Swivel the phone open.
  3. How to fix a wobbly Sony Ericsson w600i swivel: step 3, image 1 of 1
    • Using the Spudger, gently pry up the U-shaped grey cover below the keypad.
    • The cover is secured with adhesive tape. The gentler this is removed, the easier it will be to reassemble.
  4. How to fix a wobbly Sony Ericsson w600i swivel: step 4, image 1 of 1
    • Remove the two Torx screws from below the cover.
    • These are T5 Torx screws, 8.6mm.
  5. How to fix a wobbly Sony Ericsson w600i swivel: step 5, image 1 of 1
    • Gently work a spudger or a fingernail between the keypad face and the backplate.
    • The pieces are clipped together most tightly at the bottom loop section.
  6. How to fix a wobbly Sony Ericsson w600i swivel: step 6, image 1 of 2 How to fix a wobbly Sony Ericsson w600i swivel: step 6, image 2 of 2
    • Separate the keypad face from the backplate.
    • The keypad keys and the button component are both loose inside the phone, so take note of their orientation in case they become dislodged.
    • Take note of the braided cord's state. Upon reassembly it should be returned to the same orientation.
  7. How to fix a wobbly Sony Ericsson w600i swivel: step 7, image 1 of 3 How to fix a wobbly Sony Ericsson w600i swivel: step 7, image 2 of 3 How to fix a wobbly Sony Ericsson w600i swivel: step 7, image 3 of 3
    • Holding the backplate away from the swivel, remove the 4 small Phillips screws and both stamped struts from the swivel assembly.
    • Note that only the bottom strut has a tab.
    • The screws are Phillips, 2.9mm
  8. How to fix a wobbly Sony Ericsson w600i swivel: step 8, image 1 of 1
    • The back housing is now disassembled, and the swivel assembly is revealed.
  9. How to fix a wobbly Sony Ericsson w600i swivel, How to fix a wobbly Sony Ericsson w600i swivel: step 9, image 1 of 1
    • Tighten the four small Phillips screws.
    • The swivel assembly should now be less wobbly and loose, improving the function of the phone.
    • The screws are Phillips, 2.4mm.
Beau Blanchard
20 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 610
